Grid leak biasing resistors are very large (10M ohms or so), so the impedance level at the input is higher than with a 1M ohm bias resistor in a cathode-biased stage. That means any em fields will be picked up more effectively by the grid leak stage. You might be able to reduce the hum by careful layout and grounding.
Also, noise should be higher due to increased thermal noise from the input resistor.
1Likes
LinkBack URL
About LinkBacks
but in a new amp with the same circuit, it is viewed negatively. Any thoughts, anyone?
