That machine looks really interesting. Good idea to use the glass guide. I wonder if the tensioner wears out of spec over time? Hope getting parts and repair/maintenance is doable. Can it interface with a PC?
Are you sure the min spec is 40 AWG, because the ebay page says 0.04mm. That's more like 46 AWG. I think they mistranslated that. It'll probably do 46 AWG. 44 AWG is small enough to get good midrange phase accuracy from average wind count Hi-Z coils. You may notice the difference in your results. You should be able to get no eddy current losses with quality annealed poly wire. Of course, you need to make sure tension doesn't cause insulation stretching when the wire goes around the bobbin ends. I'd guess you'd have to wind a little looser than recommended to achieve that. Inductance will drop a little, but at least you won't get increased capacitance, or dreaded high end damping eddy currents. I don't know if you can do this, but it's important to check the
series inductance, so the pickup's are in spec with planned goals. HP makes a meter for a few $100 that will give accurate series readings. I can find out the model if you want. There's also a way to check for eddy currents, so you can fine tune tension for the most consistent results. If you can make hide, or hair of it, this post explains about how to do it, and why:
DC resistance don't mean diddly - Telecaster Guitar Forum
I'm not a winder, but have learned a good deal about the process in the last several years. I have talked extensively with Bill Lawrence and his team members, and have read through all his writings and patents. I know it's a point of controversy in the winding community, but I wouldn't bother with winding patterns, or scattering. Essentially, it just moves more of the coil away from the core, compromising efficiency. I'd focus on coil dimension/density/volume within a given magnetic field shape/density/power to maximize phase accuracy and efficiency, but that's me. I'm curious how your new experiments go. More power to you, Sonny.
