| | #1 |
| Senior Member Join Date: Jun 2006 Location: iowa
| shielded wire?
who do you guys use for shielded cable (for high gain amps between stages...) looking for something small and flexible (hot+shield)-cant find any at Mouser. |
| | #2 |
| Junior Member Join Date: Jun 2006 Location: West Palm Beac FL
You can go to Raido Shack & just buy a jumper wire that has mini RCA jacks or phone jacks on the ends & then just cut them off. There are usually 3 or 4 to choose from, some have a thicker center wire than others. I have a bunch of sheilded wire that came with old reverb amps that I have bought to utilize the transformers, the wire that goes from the tank to the amp, I have bundles of it. If you really need a peice E-mail me & Ill send you some. "Only for another Mopar guy" . How long does it take you to get your headers out? Ha-Ha JOE
__________________ Resistors not Transistors ! |
| | #3 |
what size is the wire? im looking for some fairly small stuff... i have fenderwell Hookers in the car--should take about 10 minutes to lift one out.. |
| | #4 |
You need to be very careful on the capacitance of shielded wire. Some can have as much as several pF per foot which can alter the tone of the amp. Go to apex jr and get the stuff he sells, very low capacitance and easy to work with. http://apexjr.com/ |
| | #5 |
| Member Join Date: May 2006 Location: central Illinois
I use GG-174 mimi coax from www.jameco.com |
| | #6 |
| Senior Member Join Date: May 2006 Location: Manassas, VA
or give Willie at NBS Electronics a shout....
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Heavier gauge wire for bass pups | Stan H | Pickup Makers | 8 | 03-25-2009 07:53 PM |
| Source for 600v solid core hook-up wire ? | Paul P | Build Your Amp | 12 | 08-05-2007 02:11 AM |
| magnet wire price | EtLa | Pickup Makers | 27 | 11-20-2006 07:37 PM |
| Alnico types, magnet and wire vendor links | DrStrangelove | Pickup Makers | 9 | 07-05-2006 11:56 PM |
