Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 05-27-2007, 02:42 AM   #1
Supporting Member
Steve A.'s Avatar
Peavey Valve King Royal 8 / Orange Tiny Terror head
The Peavey Valve King Royal 8: 2 tubes / 5 watt Class A, like the Epi Valve Junior, but with 3 controls: volume, tone and gain. I was checking this out in the local music emporium yesterday, comparing it to the Orange Tiny Terror head, which is switchable between 7 and 15 watts. A peek in the back revealed two preamp tubes and two EL84's.
With both amps, the single knob tone controls work fairly well, rather than going from too bassy to too trebly, with a narrow range of usable tones.
So does anybody here have schematics for either of these amps? It'd be interesting to see how they compare. It might be also be interesting to add some of the circuitry to the Epiphone Valve Jr amp...
BTW the Tiny Terror head is advertised as Class A so I suspect that the 7/15 watt switch might turn off one of the EL84 output tubes if it is using a single-ended pair in parallel.
Steve Ahola
Steve A. is offline   Reply With Quote
Old 05-27-2007, 05:39 AM   #2
Steve, there was a thread on the TT at TGP recently, I think someone posted a schematic. It is a pp amp and not SE.
Mike
teleamp is offline   Reply With Quote
Old 05-27-2007, 03:20 PM   #3
Quote:
Mike
Mike and Steve A.,
The schematic was originally posted in a thread on this site:
Anyone know what the "tiny terror" circuit is?
You are correct, the TT is push pull.
steve
steve is offline   Reply With Quote
Old 05-28-2007, 10:06 AM   #4
Supporting Member
Steve A.'s Avatar
Quote:
Originally Posted by steve View Post
Mike and Steve A.,
steve
Thank you kindly! I failed to use the search feature here... my bad!
I was looking at the post-PI master volume control, thinking- wow that is different, with no extra caps, but I guess that they can get away with it being cathode biased, so there is no bias voltage going through the dual ganged pot. And the tone control is the familiar AC-30 cut control, only wired up "normally", with fully clockwise being brighter and fully ccw being deeper.
Steve Ahola
P.S. What is the circuit normally used in the Marshall 18 watter? A Marshall model number might be sufficient since I think I have all of the older Marshall schems... I'd like to see how the 18 watter compares to the Tiny Terror.
Old 05-30-2007, 01:22 AM   #5
I'll see if the PV drawing is up on my dealer site after dinner. Right now my bandwidth is limited on my dial up.
Old 05-30-2007, 01:25 AM   #6
It's there, I'll send it to you.
Old 05-30-2007, 01:50 PM   #7
TD_Madden's Avatar
I have a 'dummy" question regarding part of this thread....isn't it possible for an amp to be push-pull and STILL be "class A"?
TD_Madden is offline   Reply With Quote
Old 05-31-2007, 12:40 AM   #8
Of course.
What they were wondering above was whether the two output tubes they see were p-p or SE in parallel.
SE is obviously class A. p-p can be either class A or something else.
Old 06-25-2007, 09:36 PM   #9
Supporting Member
Steve A.'s Avatar
Quote:
Enzo already answered your question, but AFAIK the debates are still going on whether the Vox AC-30 is actually "Class A". I guess the amp mfgs just go with the popular definition of Class A... cathode biased, with the tubes hot enough to melt flesh. LOL
Anyone know what the "tiny terror" circuit is? FatGaz Guitar Amps 194 03-04-2010 02:36 PM
What speakers for Epi Valve Jr head steelman Guitar Amps 23 01-17-2009 10:09 PM
Mods performed on Peavey Valve King 112 Aircop Mods & Tweeks 5 06-16-2007 12:40 AM
(new) Valve Junior head noisy problem The Captain Maintenance, Troubleshooting & Repair 8 11-19-2006 02:39 AM
Want to build an Orange head elvisjer Theory & Design 3 08-21-2006 11:03 AM
