Old 05-30-2007, 11:29 PM   #1
Strange Buzzing problem
My amp is a 1980 Fender 75 ,and whenever i turn it on, it makes a loud buzzing sound. The buzz is also very random. I could turn it on and it will start buzzing immediately, or i could be playing for five minutes and then it will start buzzing. Can anyone tell me what's wrong with it and how i can fix it? Please
Gordon303 is offline   Reply With Quote
Old 05-31-2007, 01:50 AM   #2
Mars Amp Repair's Avatar
is buzz present with volume turned down....guitar unplugged? Try balling up your fist & banging the amp hard on the top....does buzz change? If so you're probably looking at a bad connection in the amp somewhere. glen
Mars Amp Repair is offline   Reply With Quote
Old 05-31-2007, 02:29 AM   #3
I agree, if banging the top of the amp either makes the hum stop or makes the hum start - of it affects the hum at all - there is a loose connection. Most likely one or more of the main filter caps needing resoldering.
Old 05-31-2007, 02:37 AM   #4
Don Symes's Avatar
There's also the step of checking that all the jacks are tight - especially the input jack. Some models rely on that connection for ground.
R.G.Keen has this great tube amp debug page - and a lot of the diagnostic steps apply to solid state, too.
Hope this helps!
Don Symes is offline   Reply With Quote
Old 05-31-2007, 02:41 AM   #5
well i dont know if i described the sound right. Its more of a loud fluttery BRRRRRRRR!, but my dad said cone isn't busted. I also hit the top of the amp just to check and it didn't affect BRRRRRRRR sound.
Vox AC30 wild buzzing Mars Amp Repair Debugging Your Build 3 04-17-2007 05:22 PM
I have a strange amp. Arthur Dent Mods & Tweeks 5 01-30-2007 01:59 AM
First build being strange Arthur Dent Debugging Your Build 8 01-23-2007 09:15 PM
Strange output stokes Maintenance, Troubleshooting & Repair 8 11-23-2006 05:49 AM
fender roc-pro 1000 buzzing acorkos Maintenance, Troubleshooting & Repair 2 09-24-2006 04:15 PM
