Results 1 to 8 of 8
Thread: Fender blues DEVILLE repair. Blown R3000 diodes + Insane noise
    Dec 2012
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    First of all a big hello to the musicians and amplifier techs here!
    I repair amplifiers part time at home, i mainly want to continue making guitar pedals but Reputation gets around and amp repairs help fill my gas tank. (Vertical Amplifiers is my company name)
    A friends Fender DeVille would work and play fine, and then after a few minutes the speakers would go into shock with LOUD buzz.
    Replaced the blown R3000 diodes(D5-D4) with 3-1000v rated diodes in series for each side.
    Now the buzz is instant as soon as standby is switched on. I was thinking the Output Transformer is shorting (because what had blown D5-D4 may also have damaged the OT) but both Blue and Brown measured 50ohms and 54.5ohms to the Red centertap. Are those normal resistance on the primary coils?
    I will check the Phase Inverter plate voltages tomorrow and R57. Also those solder joints like Enzo+52Bill had suggested in previous posts.
    Im working 12hrs a night right now (8pm-8am) so im having time trouble to find and fix issues and am glad i found this forum.
    BTW- SWR SM900 bass amps are my nitch. Two friends have them and i have fixed many issues and quarks if you are having trouble with them!
    -Will
    0 Not allowed! Not allowed!
    Dec 2012
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    -UPDATE- pin 3+8 Phase Inverter voltages are at zero. However the voltages are on pins 3+8 for 5 seconds when the amp is cold started!
    -UPDATE 2-
    Replaced the tube- BAM problem solved.
    When the PI (a JJ' ECC83S) Heated up to normal temp for some reason current would stop flowing through the cathodes... Just a bad tube. Hope this helps anyone! he said he had just replaced the preamp tubes. I have had 1-2 JJ' brand tubes be DOA right out of the box. But I love there sound, will just have to buy tested ones.
    Dec 2008
    Wernersville, PA
    12,203
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    Nice fix!
    Which begs the question 'why did the flyback diodes fail?'
    NYC
    1,652
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Jazz P Bass View Post
    Nice fix!
    Thats what I'd like to know.A bad PI tube would not cause that.I think that amp will be back soon.
    Sep 2013
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Did you remove the diodes from the circuit to check them? I know this is silly but I thought I'd ask, given that measuring them in circuit would give a zero diode check or other, due to being across the primary.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    The flyback diodes are not across the primary. They are from each end of it to ground. That essentially puts them across the B+ supply.
    If one is shorted, it will reads so and ground the B+ at that point. If the other one is still good, at its cathode we would find the resistance of the primary to ground. Unless your B+ is shorted to ground or your primary is shorted to frame or secondary, ther is nothing to make the diodes appear shorted.
  7. #7
    Sep 2013
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I understand what you are saying... when I looked at the schematic I thought the primary centertap was at ground. Something must have really juiced up those diodes!
  8. #8
    Lifetime Member
    4,249
    Thumbs Up/Down
    Received: 4/0
    Given: 0/0
    Flyback diodes have nearly 2x B+ across them. The on-side output tube pulls down to within 50-75V of ground when it's turned on hard, and the off-side tube plate flies up to B+ plus the voltage across the other side by transformer action.
  1. Fender 212 Deville Running Guitar & Mic (blown resistor)
    By tofearthewolf in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-15-2012, 06:37 PM
  2. Fender DeVille 212 - Distortion Channel Blown Out (checked speakers and tubes)
    By tweety3537 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-25-2011, 04:07 AM
  3. Fender Blues Deville - No Reverb
    By Wildcard in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2011, 12:23 PM
  4. Fender Blues DeVille Faceplate?
    By Mark Black in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-16-2009, 07:41 AM
  5. fender quad reverb blown, repair help.
    By rochotte in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-21-2008, 10:20 AM
Tags for this Thread
