Results 1 to 4 of 4
Thread: Crest CA6 Power amp- in protection on one channel
    Dec 2012
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello Tech world
    I am new hear to this furum.This Crest amp came in with all the syptoms of a short in channel B. Channel A worked fine with PWR harness of B diabled. Now after bringing it up on the variac with channel A PWR diabled, it showed excesive current being drawn on B. So I decided to swap out channel A in place of B with maintaining A PWR harness disabled. It then showed a short with Channel A (the known good channel). thus leading me to think PWR supply problems with that side. Has anybody seen this problem any leads would be helpful. Thanks.
    0 Not allowed! Not allowed!
    Near Seattle, WA, USA
    663
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Most power supply problems will be present even without an output module installed, so check for proper rail voltages that way first.
    Could also be a problem on the preamp board, but that usually only happens after a major fault in an output module so comparison-check all the semiconductors between the working and suspect modules with a meter set to diode-check before doing a lot of module swapping.
    Problems on anything other than the output modules are kind of a PITA to run down on the CA series due to physical construction (as I'm sure you have noticed).
    Probably not the immediate problem - but look for any bulging or leaking main filter caps on the power supply board. Most of the CA amps I saw in recent years had caps that were starting to go. The smaller electrolytic caps on that board also tend to "dry-out" and go high-ESR.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,913
    Thumbs Up/Down
    Received: 87/1
    Given: 0/0
    Start at the start, check the main rectifier bridge(s) and filter caps.
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    644
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    crest ca6, ca9, ca12, ca18 for reference
    I hope they help
    Attached Files Attached Files
  1. Power Transformers With Internal Thermal Protection Fuse
    By TomCarlos in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-18-2014, 12:51 PM
  2. EV 7200 power amp 1 channel not working
    By treatmint in forum Music Electronics
    Last Post: 06-30-2011, 12:43 AM
  3. Reverse Diode protection for Power Tubes?
    By leadfootdriver in forum Mods & Tweaks
    Last Post: 03-09-2011, 05:48 PM
  4. Bad Crest CA6 power supply
    By clintronics in forum Music Electronics
    Last Post: 09-04-2007, 05:54 PM
  5. Crest power amp
    By tonezoneonline in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2006, 08:31 AM
