Hey,
I'm glad you opened this theme!
(see my Rivera Fandango thread in this forum section)
I'm not sure what are you talking about...in my case,I didn't find any melted/cracked solder,neither a wrong bias but,of course,both can happen when a tube or both fail or if someone with little knowledge turned "by ear" the bias trimpot.
Yep,the're some sort of Frankensteins as the screw-tapped ears are most common for chassis mount.
I suspect this mount type to be the primary reason for the output tubes' mechanical destruction (they become microphonic in no time).The loudspeakers'/box/chassis vibrations are merciless transferred due to the sockets' tightness.
I've seen them once in a while (ebay and some small web stores) but,AFAIK,there's no steady source.
Regards,
LinkBack URL
About LinkBacks
