| | #1 |
| Lowering power in the 5150 II
Hi, Someone over here asks for a triode/pentode switch mod done on his 5150 II Is this feasible on this amp? I guess I will have to cut at least the four 2nd grid tracks on the pcb, and drill a hole on the back panel to hold the switch there. Has anybody tried this mod on the 5150? Thank you. (I personally don't like the "triode" sound in guitar amps) |
| | #2 |
Anything is possible, it is all a matter of how much effort one wants to put into it. With enough cutting of traces, one might consider removing the power tube circuit board, mounting sockets to the chassis and hard wiring the output stage. Instead of trace cutting, couldn't we just lift one end of each screen resistor and insert the wiring there? |
| | #3 |
| | #4 |
I don't have one to look at, but it COULD be that easy. You'll have to look at the board for any extra little circuit branches I am not remembering.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Problems with my 5150 combo | trenolds39 | Maintenance, Troubleshooting & Repair | 9 | 04-30-2007 02:54 AM |
| Peavey 5150 t-former ?? | spiderman2812 | Maintenance, Troubleshooting & Repair | 25 | 04-07-2007 01:45 PM |
| Peavey 5150 problems! | spiderman2812 | Maintenance, Troubleshooting & Repair | 11 | 04-03-2007 05:57 AM |
| Peavey 5150 Problem Diagnosis - Bass Boost/Power Supply | LOGANSTL | Maintenance, Troubleshooting & Repair | 4 | 03-03-2007 03:34 AM |
| Difference between 5150 and 5150 II? | Gregg | Theory & Design | 2 | 01-29-2007 09:25 PM |
