Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 06-21-2007, 11:49 AM   #1
Ampeg Gemini OT primary impedance
Hi all, I'm wondering what's the primary impedance of Ampeg Gemini I & II trannies. (OT-151 & OT-225) They both use 7591A tubes @ 365 & 430 volts respectively giving 20 and 30 watts.
Looking at the tube 7591A data, in most operation conditions they need 6K6 aa load resistance in AB1 class. But with these voltages and biasings (15V Cathode biased & -22V fixed) power should be higher. Am I missing anything? Are trannies impedances higher than 6K6 in these amps?
I have a bunch of matched NOS Sylvania 6L6-GA tube pairs. I'm wondering how good would they work on these amps. That voltages and a 6K6 OT would be perfect for them (of course rewiring the sockets). Is this a good idea?
Thanks in advance.
Snapcase is offline   Reply With Quote
Old 06-21-2007, 02:48 PM   #2
My calculations say both these Ampeg OTs are 8k Raa. Based on 7591 data, B+ 360 re 430 and given rated output power of the amps 20/30W. The 30W OT should be marginally bigger than 20W.
You can rewire for 6L6GA without problems, in the 20W amp expect slightly more output power around 25W because 8k Raa is close to optimum 9k for this tube at 360V, provided B+ doesn't sag more than to around 350V.
The 30W amp with 430V B+: a 6L6GA might not take it too well.
__________________
Aleksander Niemand
Tubewonder amps
Life's a party but you get invited only once
Alex/Tubewonder is offline   Reply With Quote
Old 06-21-2007, 03:58 PM   #3
Thanks a lot for your reply. I'll try the 6L6GAs. The JJ 7591s sound good setting the amp around halfway volume, but pushing it further they compress too baddly and doesn't give enough volume for gigging. 25 real watts and more headroom look a sweet improvement for the Gemini I.
Old 06-22-2007, 12:41 AM   #4
My factory service info calls for the OT215 in the Gemini 2 (G-15).
It lists 6.2k and 8/16 ohms.
Old 06-22-2007, 07:13 PM   #5
Yes, this is the OT for the 6L6 version of the Gemini II. The earlier G-15 version used 7591A tubes, an OT225 tranny and lower plate voltage.
7591 G-15
http://www.kbapps.com/audio/schemati...ampeg/g15.html
6L6 G-15
http://www.kbapps.com/audio/schemati...mpeg/g15b.html
Anyway, it's quite interesting knowing the OT215 data. Thanks a lot, Enzo.
Old 06-23-2007, 02:36 AM   #6
Actually that tranny is listed with both 6L6 and 7591s.
I have found the OT151, and it shows as 6.6k and 8 ohms.
I am running through the book colecting this data and will post in a couple hours what I find.
Old 06-23-2007, 06:36 AM   #7
I found these, impedances and the tubes they were used with in the examples found:
OT-149 10k, 8 ohms 7591
OT-150 10k, 8 7591
OT-151 6.6k, 8 7591
OT-208 6.5k, 8/16 6L6
OT-213 6.5k, 8/16 6L6
OT-215 6.5k, 8/16 6L6/7591
and for comparison:
8950004 1850 ohms, 4/2 ohms 6146B/6550 (SVT)
Old 06-23-2007, 09:02 AM   #8
Hey, this info is great, Enzo. Big thanks!
Ampeg Gemini G-15 service questions mattattnet Vintage Amps 15 07-31-2007 02:47 AM
PP 2.5k primary Output Transformer walkman Theory & Design 8 06-17-2007 07:48 PM
Primary impedance for 4x6L6? Hallingamp Theory & Design 25 05-09-2007 03:59 PM
Primary Z early Portaflexes Chris / CMW amps Theory & Design 2 05-01-2007 09:48 PM
Failed primary winding on Power Tranny? hasserl Maintenance, Troubleshooting & Repair 5 08-01-2006 01:48 AM
