| | #1 |
| Member Join Date: May 2006
| 12BY7A pentode or triode in a guitar amp
Hi, I have a couple of 12BY7A tubes that I would like to use in a guitar amp. I have found that they are high gm pentodes. Can they be used as the first tube in a guitar amp? I would like to test them as a pentode and as triode but I cannot find a typical circuit on the net to get started. Does anybody know typical plate , screen and cathode resistor values? I have build an EF86 based amp that I would like to adapt to test these tubes.... Thanks, Jelle |
| | #2 |
| Senior Member Join Date: Aug 2006
| Wrong Position
12BY7s are power output valves, not preamp valves. Here's what TDSL brought up: http://tdsl.duncanamps.com/dcigna/tu...ets/12by7.html |
| | #4 |
Thanks for the replies! I had already seen that they are videopentodes...what does this mean other than bandwidth? I also found out that this tube is used in the Harman Kardon Citation II. Please see: http://www.bassboy.com.au/getreel/si...rcuits/cct.gif Can I use this tube instead of a EF86 in the preamp? It may need some rewiring and different resistor values. Can I use the Citation II first input wiring for this. And is there a set of resistor values that work for the triode mode? Any help is appreciated. Thanks! Jelle |
| | #5 | |||
| Quote:
Quote:
Quote:
| | #6 |
I will try this in the next days. Thanks for the answers. I will report back when I have some news. Looking forward to test it! Jelle |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Valve Junior Triode / Pentode switch | grandmasterflash213 | Mods & Tweeks | 8 | 07-19-2007 08:51 AM |
| '66 Bassman triode/pentode switch? | grunt | Mods & Tweeks | 8 | 04-05-2007 01:13 AM |
| new build/pics with 6AU6A pentode preamp | Alexander | Theory & Design | 12 | 01-25-2007 08:51 AM |
| OT w/ multiple secondaries & triode/pentode switching | brainstatic | 5 E 3 | 0 | 11-29-2006 07:11 PM |
| Mesa Mark III triode/pentode question | AtomicMassUnit | Mods & Tweeks | 1 | 09-10-2006 04:51 PM |
