Look for an open resistor at the phase inverter tube. I'd bet one of the plate resistors is open. This is a class AB amp, so at low levels, one tube of the pair can handle the entire waveform, but as you increase the volume, you get to the point where the other tube is necessary to reproduce the entire waveform. If that tube is not in the loop, then you get distortion, yes crossover-ish distortion.
Of course ti could be something else...
As to the vibration, I wouldn't worry, most likely just the power transformer.
LinkBack URL
About LinkBacks
