Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 06-30-2007, 10:16 PM   #1
5E3 Fuse ?'s
Hi all,
Does anyone here use extra fuses in their 5E3 builds other than the 2 amp from the wall? That's a slo blow right? I'm curious if there are other safety spots to add a fuse or two in to preserve parts from potential damage? Certainly let me know if I'm thinking overboard here as I am making my first build and want it to be just right.
Thanks!
cooper
www.blanketeer.net
www.myspace.com/blanketeer
cooper is offline   Reply With Quote
Old 07-02-2007, 11:58 PM   #2
Well in Uk we use one in the wallplug at ~3A & then another, the amp's sloblo at 1A.
The Captain is offline   Reply With Quote
Old 11-24-2007, 07:17 PM   #3
I suppose you could put a 160mA fuse on the B+, isn't the max output rating for a 5Y3GT 125mA?
ValveBytes is offline   Reply With Quote
Old 11-29-2007, 01:47 PM   #4
well, I fuse both sides of the primary (and switch both sides). I don't know if it makes a difference, but the wall plugs aren't polarized here and you never know which side is hot. Switching both sides is code here. I also put a fuse on the HV secondary. It doesn't cost much extra time, money, or effort, and doesn't hurt anything, so I just go ahead and do it.
steven
sjhust is offline   Reply With Quote
Super Reverb fuse blowin AtomicMassUnit Maintenance, Troubleshooting & Repair 14 02-02-2009 11:18 PM
HT fuse just won't stop blowing. MitchK Maintenance, Troubleshooting & Repair 44 06-15-2007 05:08 AM
Roland JC-120 fuse blowing Lebowsky Maintenance, Troubleshooting & Repair 12 06-13-2007 12:41 AM
Easy fuse question davoux Maintenance, Troubleshooting & Repair 2 02-05-2007 12:55 AM
acoustic model 450 fuse holder wardevans Maintenance, Troubleshooting & Repair 1 10-10-2006 07:09 PM
