Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By Randall
  • 1 Post By warmbooter
  • 1 Post By Randall
Thread: Reverb "hum" in Marshall VS100
    May 2009
    5
    Question Reverb "hum" in Marshall VS100
    Hi!
    After many months without turn my Marshall VS100 on, I was surprised when I turned it on and found that the reverb seemed to not be working. So, I unplugged the connectors of the reverb tank and sprayed a contact cleaner solution, and it seems to make the rever work again.
    The problem now is that there is a constant "hum" noise coming from the reverb, and afair, this didnt happen before. I recorded this in the following video.
    I also noticed that if I attach a wire to the tank and ground it to my iron door, the noise goes away (but this is not a solution, since I cannot assume that I'll be able to ground it anywhere I go).
    Any tips about this problem?
    Thanks!
    Carlos
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,380
    Looks like you lost the shielded ground connection on the wire with the red connector. If it connects to rca jacks on the chassis somewhere, you can just replace that cable. If the wires disappear into the chassis, then the chassis needs to be pulled to inspect and repair the connection where it is soldered to the board, or replace the wire.
    Fragger likes this.
    May 2009
    5
    I removed the two internal connectors inside the reverb tank (that are wired to the RCA plugs and connects to the springs module) and repluged them, and the noise is gone. Weird... I hope it will not come back.
    Jan 2013
    Cape Coral, FL
    1,380
    In that case, I would give both those connectors a little squirt of cleaner. It'll be fine.
    May 2009
    5
    Yep, I sprayed contactmatic on both, and re-plugged it two times to make sure any "dirty" was removed. I just hope this was the real problem, and not just a temporary solution.
    gtrplayr1976 likes this.
    Jan 2013
    Cape Coral, FL
    1,380
    I expect you fixed it. Just a dirty connection. Happens all the time. I fixed one recently that wasn't making any reverb, same fix. The difference is I lost the signal connection, and you lost the shield connection.
  1. Replies: 0
    Last Post: 04-18-2013, 11:21 PM
  2. Fender Twin Reverb/"custom" Vibrolux Reverb foot switch noise
    By mrkgtr49 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-19-2012, 12:16 AM
  3. '72 SF MV Twin Reverb "bright switches" cause pop and hum
    By booj in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-21-2011, 06:45 PM
  4. Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died
    By Renegade44 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 06:24 AM
  5. Ampeg SVT Classic - How Much Background hum is "normal"?
    By wizard333 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-22-2009, 04:59 PM
