Results 1 to 5 of 5
Thread: Alesis MicroVerb schematic needed
    Supporting Member Tone Meister's Avatar
    Aug 2012
    North Carolina, USA
    606
    Thumbs Up/Down
    Received: 1/1
    Given: 1/0
    Need a schematic and any available TSBs for an Alesis MicroVerb from October 1986.
    0 Not allowed! Not allowed!
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    644
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    microverb 4 & midiverb 3 schematic in case they help, if not then they are here for posterity (hopefully)
    Attached Files Attached Files
    Aug 2012
    North Carolina, USA
    606
    Thumbs Up/Down
    Received: 1/1
    Given: 1/0
    Thanks for posting those Mozwell, those are great to have in the library; however, my unit is a desktop mini-chassis and the MicroVerb 4 is a rack mounted unit. My unit is significantly less sophisticated and it seems like there is very little resemblance between the two other than in name.
    Jul 2007
    562
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Alesis supplies for many companies both chips and small boards used for delay/reverbs in different devices.
    This board is showed in the devices’ service manual usually as a block (as on the block diagram) with inputs/outputs and powering. Internal electrical schematic is absent.
    This label means only that a specific or modified SW version of the Microverb is used.
    You need to repair this board using common knowledge about digital reverb: ADC, DSP, Memory, DAC, etc.
    Aug 2012
    North Carolina, USA
    606
    Thumbs Up/Down
    Received: 1/1
    Given: 1/0
    Quote Originally Posted by doctor View Post
    ...You need to repair this board using common knowledge about digital reverb: ADC, DSP, Memory, DAC, etc.
    Thanks Doctor, but that may be a little above my capabilities. This unit really isn't worth the time I will end up putting into it, but it does belong to me so I wanted to attempt a repair if feasible. As you can probably tell, I am merely a novice hobbyist and am attempting to increase my knowledge incrementally. Thanks again!
  1. Alesis ML-9600 Schematic
    By rf7 in forum Schematic Requests
    Last Post: 05-13-2017, 08:53 AM
  2. Alesis MicroVerb - passing signal but no effect
    By Tone Meister in forum Music Electronics
    Last Post: 10-31-2013, 12:45 PM
  3. Schematic request Alesis tubeduo
    By keithsplace1 in forum Schematic Requests
    Last Post: 03-17-2013, 04:16 AM
  4. Alesis QUADRAVERB schematic...
    By pecorporation in forum Schematic Requests
    Last Post: 06-11-2011, 02:56 PM
  5. Alesis MidiVerb II Schematic
    By stosostu in forum Schematic Requests
    Last Post: 05-03-2010, 05:33 PM
