Results 1 to 3 of 3
Thread: PHONIC 780 PLUS schematic needed
    Dec 2013
    1
    Hello all!
    I am working on a PHONIC 780 plus powered mixer. The problem started with the effects display acting intermittent with the effects not working consistently and now there is no audio output, the cooling fan has stopped working (bench tests ok) and the effects display does not function at all. I suspect a low level power supply problem (?)
    Also does anyone know if the Phonic brand equipment is the same as Behringer equipment? I've seen several comparisons on the net so I was just wondering.
    Thanks for any assistance you might have!
    Curt in Ohio
    Dec 2008
    Wernersville, PA
    11,966
    I believe that that unit uses a switch mode power supply.
    I never had any luck getting the schematic.
    Old Timer oc disorder's Avatar
    Jul 2006
    Land Down Under
    1,265
    There are several Phonic diagrams at Elektrotanya Service manual, eprom result list | ElektroTanya | Service manuals and repair tips for electronics experts but not the 780 Plus.
    I'm not sure who copied who but I think they bear a remarkable resemblance to the early pre smps Yamaha models like the EMX 640.
    Behringer like to have a finger in every pie so I guess they have similar models too !
    They do have the 740 a lower wattage output powered mixer
    PHONIC POWERPOD 740DELUXE Service Manual free download, schematics, eeprom, repair info for electronics
    and the 1860 which has a higher wattage powered output.
    PHONIC POWERPOD 1860 DELUXE Service Manual free download, schematics, eeprom, repair info for electronics
    Without printing them out and studying them I suspect they are very similar apart from some higher rated components in the 1860.
    My guess is your supply will bear a resemblance to these .
    Here are jpg's (aprox 500k each) of those supplies taken from the linked manuals.
  1. Micro phonic EL34's...common?
    By fredcapo in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-21-2013, 05:06 PM
  2. Replies: 8
    Last Post: 04-23-2013, 10:35 PM
  3. Phonic Sem712A
    By strato56 in forum Schematic Requests
    Last Post: 09-27-2012, 05:56 PM
  4. Phonic DMX 2501
    By doctor in forum Schematic Requests
    Last Post: 04-04-2012, 08:40 AM
  5. Phonic 740
    By bramley in forum Schematic Requests
    Last Post: 12-02-2010, 01:38 PM
Tags for this Thread
