Results 1 to 4 of 4
Thread: Power Supply probs - I'm a novice, HELP!!
    Jul 2007
    2
    Hello,
    New to this forum and to tube amp repair in particular. Just need a bit of advice...
    Got an old Carlsbro amp, has been good as gold until the other night when it shut down. Checked the fuses, and sure enough, the HT was fine but the mains had blown. So, I get a new fuse and pop it in there. Get power for about a second or two and then the fuse blows again. Have tried multiple fuses, still the same results.
    Is this an easy to fix problem? Is it something scary? Any help you could give would be much appreciated!
    Sam
    Jun 2007
    180
    Lightbulb
    does the fuse still blow with the power tubes removed?
    if it does not blow you might want to change output tubes, if it does still blow you could suspect a shorted diode in the power supply. anyhow from what you have described, I would suspect a shorted diode.
    what size fuse is the HT?
    Jul 2007
    2
    Its a 2amp slow-blow/time delay. I'm UK-based, if that makes any difference? I'll try the power tubes later. Thanks for the advice!
    Jul 2007
    Indianapolis
    681
    Basically, the fuse is popping because there is some OTHER problem - the ufse just keeps it from catching fire.
    That you're in the UK, using an amp intended for UK mains voltages(?), makes no important difference once you're on the secondary side of the power transformer.
    Do you have a multimeter (VOM, DVM, tell us which)?
    Have you ever been inside a tube amp (familiar with the safety issues)?
    It's probably something simple, but bypassing the fuse - or putting in a bigger one, is a very dangerous and destructive way to find out what.
    R.G.Keen's Tube Amp Deebug page is a good place to start.
  1. DC Power Supply for SRD Rockman
    By jsharpe@bigpond.net.au in forum Guitar Effects
    Last Post: 06-07-2009, 08:41 AM
  2. Power supply ground buzz....
    By dave251 in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-25-2007, 11:55 PM
  3. high power supply voltage
    By Hubie in forum Debugging Your Build
    Last Post: 05-03-2007, 11:30 PM
  4. Power supply filter caps?
    By savage in forum Theory & Design
    Last Post: 03-29-2007, 10:22 AM
  5. Console Power Supply modules
    By Matt R in forum Music Electronics
    Last Post: 09-12-2006, 04:24 PM
