| | #1 |
| Senior Member Join Date: Jun 2007
| insulation type
Hey guys, I was wondering if the type of insulation was more important than the build thickness. I have Jason's book, 2nd edition I think, in which he states he did not believe the insulation type made much difference. I hope I have that right, anyway to me it would seem to be the build thickness as the most important of the two. I mean wouldn't poly the same thickness as formvar sound the same? |
| | #2 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
I also don't believe the type of insulation has much of an effect, but the thickness (build) does. A thicker build spaces the wire farther apart.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #3 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
| My opinion.....
build will have more effect than insulation type but insulation type does have an effect and I'm sure some others will chime in on this. Plain enamel and poly do sound different, PE sounds more dry/organic/vintage while poly sounds more modern/splashy/rock. I've only used formvar in heavy build so its hard to say what single sounds like versus the others.
| | #4 | |||
| Quote:
This brings us back to the "dielectric dispersion" mentioned in the thread on the tube-o-lator lacquer. I started reading that article, and found another interesting reference here where the inventor is talking about a "dispersive delay line" that splits the full band audio signal into it's various frequencies, as a prism does with white light: (from the first article) Quote:
Quote:
This would also validate the whole "skin effect" in the audio frequency range, which is what Monster Cable has been saying all these years.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |||
| | #5 |
| Senior Member Join Date: Jul 2006 Location: Detroit, Michigan
It absolutly does make a difference. PE wins everytime (in my opinion). I have countless Hrs of R&D.....Its a fact. Schwab has been resisting the notion almost every time, and has never agreed in this (shhhh, He's a bassplayer that plays guitar). The best thing you can do is wind 2 pickups and compare. Better yet- RECORD 10 second clips and compare
| | #6 |
I don't know that it really matters but could you measure the difference some way or would it be one of those "it just is" kinda things?
| | #7 |
I'm working on it...You can definately hear the difference. If I made 2 pickups with the same gauge/build....one of each, PE wins every time!! Had it not, I'd gladly save my money? Pricing is much more
| | #8 |
About a year ago I was thinking about winding some really small round coils to keep it simple (and cheap) and to make it easier to keep the coils similar but I never decided on a good way to test them. Is any of the major guitar companys like gibson still using PE? If they are there must be something to it because profit is usually the bottom line and they would use the cheapest.
| | #9 |
| Old Timer Join Date: May 2006 Location: The Dog House
It's pointless re-hashing this topic. I am a believer in coatings having their own effect on tone to a small extent. It's that small extent that makes the difference. The answer to your question Rosewood is suck it and see. Make your own informed decision and don't be bullied into accepting someone else's opinion. |
| | #10 |
| Senior Member Join Date: Mar 2007
I always find myself agreeing with Spence. I'm a relative noob and I've read there is no difference, there is a difference but you won't hear it when the band starts playing, and that there is a major difference...all from different reputable winders. I suspect there might be other factors/components that come into play that might enhance or degrade tonal differences between different insulations. That is to say, there might be a major difference between SPN and PE in Nightwinder's pickups, but not Dave Schwab's based on other tangible and intangible factors. We all have different ears too. But (as Spence suggests) ultimately you should wind two pickups as similar as possible, with all the same components (save the different insulations) and make that decision for yourself. I haven't done so myself, but I have every intention to. |
| | #11 |
+1 on that recommendation. Also, Spence usually posts answers only once....so read his posts carefully, take it and run like the dickens!!
| | #12 |
Got it. |
| | #13 | |
| Quote:
Peter Baxandall basically said the same thing. Now clearly you can hear differences in things. I can hear a difference in one pickup when you flip the phase. But I couldn't even describe that. So I think some stuff is heard by some ears and not others. For years I defended Monster cables on the BottomLine mailing list because I could hear the difference, while others couldn't. Recently I retired my 20 year old Monster cable because it was getting microphonic, and bought a "regular" high quality cable... and I can't hear a difference. So with something like magnet wire insulation, I'll read up on it, and some people seem to hear a difference, while others don't. Logically it wouldn't make sense for it to sound different just from an insulator stand point. You would think it would have to involve a change in capacitance or something. Then I stop and think about it and I agree that different materials could probably affect the tone. But since we don't know why, it's hard to validate. For instance, after revisiting the "Tube-O-Lator lacquer" thing, Dave's response made me stop and think about it... so I started reading a few more web sites and now I actually found an explanation of why that would work. So heck, if wax can change the tone of a pickup, why not graphite on the top of a plastic IC case? I sure don't know everything, and I think way too much! Oh and I started on drums, then guitar, and then bass. So I've been playing guitar slightly longer... But I'm not a guitar player that plays bass, or a bass player that plays guitar...
| | #14 |
Your too cool : ) Nothing wrong with getting the thinker thinking, I just have some serious insomia over Gear in general. Pickups Consumes my thoughts. However, you should take the plunge and get some PE, I believe you'd hear it. |
| | #15 | |
| Quote:
When you start reading enough esoteric audiophile stuff, many times they say you have to "grease your ears"; once you accept that there is an improvement in the audio system, based on some new device, you will start to hear it. So you must believe it's real. (and some of these ideas are things like "plain piece of blue paper under any vase of flowers or any pot plant in the listening room" and "aligning the slots in all screw heads so that the slots are parallel to the earth's surface.") Where do we draw the line? This is why discoveries are always made by accident, because if you don't know something exists, you can't find it! I'm heavily into metaphysics, so I should be the first one to say that reality is less ridged than we usually believe.
| | #16 | |
| Quote:
All my recent pickup experience has mostly revolved around one particular pickup design, and it's variations, and I used the wire sold by Stew-Mac because I wasn't ready to buy a boat load of wire, if I didn't know what I wanted! I got good results with that gauge and insulator. I'd love to try other gauges and insulators, but that involves buying a bulk of wire I might not use. Yet. I left my day gig to get back into building basses, so the R&D budget is a bit tight ... Now I'm actually going through the wire makers catalogs. So I listen to you guys. I see smaller rolls on eBay sometimes of various gauges and coatings. I'll have to take the plunge and try some.
| | #17 |
Just get a 5lb spool. Ask for the smallest. Sometimes they have their head screwed on right. In the meantime, heres some Eyecandy for you David. A custom Bass, and my newest snag : )
| | #18 |
| Senior Member Join Date: Oct 2006 Location: Mid Wales
| Most of the PE on ebay is really just black poly so you have to contact the seller and ask them questions about it. I'm told that the only company still making real PE is MWS.
| | #19 | |
| Quote:
So many different combinations to try out...
| | #20 |
I'm always thinking that unless you can wind two identical coils, identical in every way, then how do you know what different insulations are doing for tone. Unless, the change is so great it overcomes the slight differences in coils. If I think about it long enough my head will explode, so I'll try some PE and formvar if it's available. |
| | #21 |
| Senior Member |
I wonder if any difference in tone arising from different insulation type might be due to a difference in the coefficient of friction between the materials? A smoother coating would be slightly more microphonic, and the difference more evident in unpotted coils.
| | #22 | |
| Quote:
| | #23 |
| Tone Mechanic Join Date: Dec 2006
| | #24 |
| Sweet Axes!!!! I like the color of the Les Paul...I was looking at a Hamer Standard USA model similar to that in orange...
| | #25 | |
| Quote:
That's a pretty Paul. I like the bass. Reminds me of a Karl Thomson. Is that purpleheart in there? I use a lot of purpleheart. What, no pickups?
| | #26 |
Thanks. I thought David may like it. It is purple heart- Don't breath the dust, its highly poisonous!! The other is a Gary More Gibby, Been actually paying on it from a local collector....I tryed to coarse him into some trades, but had to dish out about $400.00 cash and a few trades. took me a while, but I like to pay all at once. He's a fairly rich fella, so he worked with me : ) the Thread: David- If you don't like what you hear....I'll buy the rest of the spool. I think many would here too(but i offered first!!) No biggy. I really want ya to try it. SHit, If I had a fairly empty spool, I'd send it to you. I'm not to much into reinventing the wheel, and I use alot of Half sizes, and different insultaion builds, but the common 42 awg is a must. 43 too for that matter too. Try to let them know that you are "trying" the new insulation type (MWS, although I have another spot too!) you may get a 3.5 lb or something. Just a thought |
| | #27 | |
| Quote:
1 guy told me it was oleoresinous enamel and gave me a brand name that wasn't MWS so I asked him how old it was. I then took the information back to the maker and didn't get any responce. So perhaps it was NOS PE but I don't really know. Unfortunatly magnet wire manufacterers aren't speedy quick when answering questions from guys like me. | |
| | #28 |
| I'm no expert and
cant explain a lot of things going on in a pickup. I have a pretty good ear for the most part. I use PE, formvar and Poly and each has their own distinct tone. PE versus Poly, well to me Poly has a more wet tone to it where as PE has a dry type tone. Formvar is like the 2 combined with a smoother feel but very nice highs and lows. Just My .02 cents worth. |
| | #29 | |
| Old Timer Join Date: May 2006 Location: Boston, MA area
| Quote:
| | #30 |
| The Immoderator Join Date: May 2006 Location: NYC Metro
| slick dielectrics
.wysiwyg { background-attachment: scroll; background-repeat: repeat; background-position: 0% 0%; background-color: #f5f5ff; background-image: none; color: #000000; font-family: Verdana, Arial, Arial; font-style: normal; font-variant: normal; font-weight: 400; font-size: 10pt; line-height: normal } p { margin: 0px; }Coupla thoughts: The insulations differ in friction and dielectric constant. A slicker insulation will pack*winds*more tightly. A higher dielectric constant = more instrinsic capacitance = lower resonant freq. MWS Wire's catalog lists the dielectric constants of insulation on page 11. ...all except for plain enamel. The poly-nylon and polyurethanes have the highest dielectric constant. Does anyone have experience with them? -drh.wysiwyg { background-attachment: scroll; background-repeat: repeat; background-position: 0% 0%; background-color: #f5f5ff; background-image: none; color: #000000; font-family: Verdana, Arial, Arial; font-style: normal; font-variant: normal; font-weight: 400; font-size: 10pt; line-height: normal } p { margin: 0px; } |
| | #31 | ||
| Quote:
Quote:
I've heard several people use the same analogies, so I have to accept that's how each wires sounds. I'm still finding it fascinating that with the same insulator, I can get very different sounds going to different gauge wires. I have some 36 gauge I'm going to mess with... Les Paul Recording pickups anyone?
| | #32 |
Oleoresinous is Plain Enamel. Many don't know that. Why so technical. Of the 2 names, I would refer to Plain Enamel.....A little more commonly known
| | #33 |
| Wondering if a certain someone is here
He hangs out at the TDPRI, a godforsaken place where all the people for the most part are snobs except for a select few, mainly the ones who hang here. His name there is rockin carl, he was winding pickups and was trying to see if he was still winding and how he was getting on. If you are here speak up Bro. |
| | #34 | |
| Quote:
If you look up "enameled wire" it says "Enameled wire is a thin wire coated with an insulating layer, used in electric motor coils. The core material is copper, coated with a thin layer of a polyurethane, polyamide, polyester etc resin - the so-called 'enamel'." So.. enameled wire can have a poly coating... what we know as "plain enamel" is oil based varnish. That makes sense. So that would be the reason to ask for oleoresin.
| | #35 |
| Senior Member Join Date: Jun 2006
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Magnet insulation | Possum | Pickup Makers | 120 | 01-17-2008 11:13 AM |
| Poly/Nylon insulation? | chevalij | Pickup Makers | 8 | 06-16-2007 01:24 AM |
| What dictates the rectifier type? | fiesta55 | Theory & Design | 4 | 06-05-2007 10:09 PM |
| Wire Insulation | eblock | Pickup Makers | 1 | 05-05-2007 10:25 PM |
| Single Film Insulation? | Paulkstadden | Pickup Makers | 9 | 03-06-2007 01:06 AM |
