Page 1 of 2 12 LastLast
Results 1 to 35 of 37
Like Tree17Likes
Thread: Biasing Blakstar HT5R
    Dec 2011
    Pretoria, South Africa
    673
    Hi.
    Want to install some new valves into this amp.
    It has two trim pots inside labeled 'bias' and 'bal'.
    There are also a couple of Test points on PCB.
    Anyone have a setup procedure for this amp??
    Dec 2008
    Wernersville, PA
    12,151
    I cannot find any hard data on setting those pots.
    I did find this link that has a few voltage measurements.
    JVM Forum ? View topic - Blackstar HT5 Head
    Jun 2007
    608
    As it states: The other pot sets the overall bias voltage, the other one bias voltage balance between the push-pull pair. Note: when you adjust balance, setting that increases bias voltage at one half also decreases it at the other half.
    You can read bias current by measuring voltage drop across the shared cathode resistor of the output stage (R33 at least in plain HT-5) but do note that the cathode resistor is 4.7 ohms (at least in plain HT-5) instead of 1-ohm or 10 ohms so you actually need to employ some very, very basic math to calculate the current from the voltage. Note that since both push-pull halves share the cathode resistor you are reading the current flow through both halves. Current flow through one half is naturally about half of that, given we assume that balance between the tubes isn't way off. Cathode voltage is also hard-limited to maximum value of about 650mV by a parallel diode (though cathode voltage should be well below that under normal operating conditions).
    So, nothing new here: You measure plate voltage (which should be around 430V - 440V, and which will vary in interaction with the bias setting) and then set bias current according to what's considered safe dissipation for 12BH7. Max plate dissipation for the tube is 3.5W (check datasheet of the EXACT 12BH7 tube type your amp uses to verify the rating) and isn't it common rule of thumb to bias to about 60% - 70% of max plate dissipation for class AB....? I guess the exact setting borderlines subjective issues of preference (hotter or colder bias) and objective issues of safe area of operation (which in the amp is already quite close to limits to begin with). Given that, there is no exact setting and even everything you measure will fall to certain margin of tolerances. Anyway, this is just as ordinary fixed bias tube amp as any other one. If you have a scope you can simply try biasing that removes the crossover notch, assuming the idle dissipation falls to ballpark of safe figures that way.
    No, Blackstar won't give any guidelines or setup procedures. According to them the amplifier has an automatic bias system and therefore you don't have to worry about biasing replacement tubes.
    ...And NO: There is no proper "bias voltage" setting. If there was, there would be no point to make that voltage user adjustable to begin with. Where you set bias voltage depends on individual tube characteristics and plate voltage, which you probably should know already. With certain grid bias voltage on a given tube you end up to certain current draw and dissipation figure at given plate voltage. I don't see the point of the threads quoting "stock" / measured grid or bias voltage figures as they are completely meaningless variables. You rebias, they change. That's the point of biasing.
    Given that, there's much more sense in this thread:
    http://www.ax84.com/bbs/dm.php?thread=473836
    Reading between the lines, the stock bias setting seems to be insanely hot 7.5mA * 430V = 3.2W (!!!), which is well above the 70% figure of class-AB, in fact, close to cooking the tube at maximum plate dissipation even when idling. Add to that the plate voltage is also very, very close to maximum ratings of the 12BH7 (450V). If there ever was deeper rocket science in proper and safe biasing then rest assured that Blackstar at least didn't seem to give a damn about it.
    As said, this is a plain fixed bias amp. The only difference is that there's also a bias balance adjustment and that the plate dissipation of a medium power triode such as 12BH7 is about decade lower than that of generic power pentodes or beam tetrodes. Biasing routine, however, is just the same.
    Dec 2008
    Wernersville, PA
    12,151
    Blackstar HT5 Schematic
    Here is the schematic of the HT5.
    Attached Files Attached Files
    Dec 2011
    673
    Ok. Got some help from Blackstar. Measure voltage across 4,7ohm resistor on cathode. Adjust to mV reading of 46mV. Adjust balance pot for least amount of hum from speaker.
    lowell and Jazz P Bass like this.
    Dec 2008
    Wernersville, PA
    12,151
    Blackstar HT5 Bias Procedure
    Amazing that they responded.
    This may be the only place on the Internet with that information.
  7. #7
    Jun 2007
    608
    So that's bit less than 5 mA per half, resulting into idle plate dissipation of about 2 watts.
    Sounds way more reasonable than that 7.5 mA reading.
  8. #8
    May 2016
    1
    Just joined to say thanks for the voltages. Just replaced my power tube and needing re-biasing. Thanks aging for sharing...couldn't find anything definitive elsewhere (just a whole bunch of people saying it didn't need biasing...)
  9. #9
    Jan 2011
    NorCal
    251
    I have a HT-5 with an issue in the power-tube circuit. R39 was burned, so I replaced R39 and R38, and tried to repair the damaged PCB (no traces lifted, but some scorching). When energized, R39 is dropping 230vDC! R38 is not dropping any DC, which seems correct, since no power tube is installed. So, what other components might be drawing current thru R39?
    I cannot find shorts in TR2 or TR3. Supporting resistors R40/43, R41/42 read OK.
    TR4 is an NPN transistor: I read only 4.2K resistance between base and emitter. Is that fault condition?
    http://amps.monkeymatic.com
  10. #10
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,390
    Does your meter have a diode check function? If so, check the transistor using the diode check.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  11. #11
    Jan 2011
    NorCal
    251
    Hmm...NPN reads OK on diode test...but D20 is shorted. Will replace.
  12. #12
    Jan 2011
    NorCal
    251
    D20 read OK out of circuit. Besides, it's just protection for the cathode path. Still chasing the short.
  13. #13
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,402
    Diode test checks the diode, but resistance check tells resistance. Your resistance test will reveal the 4.7 ohm resistor in parallel with the diode, as spelled out in the schematic. That 4.7 ohm resistor is your short, ie nothing is wrong there. The diode is there to limit voltage drop across R33.
  14. #14
    Jan 2011
    NorCal
    251
    True, Enzo, no confusion.
    I have two different HT5 schematics that both show the junction of R32 and R34 connected to ground. This does NOT match my amp. On my amp R32/34 connect the bias balance pot to the bias pot. If the markings on the SMD resistors indicates what I think, they're 12K, not 33K as on the schematic...and they DO NOT connect to ground.
    Anyone know where to find a different schematic? Guess I'll call them in the morning.
    lowell likes this.
  15. #15
    30,402
    http://bmamps.com/Schematics/Blackst...-schematic.pdf
    Please note on this drawing that "0V" means ground.
    lowell likes this.
  16. #16
    Dec 2011
    673
    The problem is this:
    The board around TR2 and TR3 is becoming conductive. The fix: Remove TR2 and TR3. Drill out the centre pin hole of each mosfet. Re-insert the fets and solder the outer pins back. The centre pins of the mosfets go through the enlarged holes and should not be touching the pcb.
    Then take some wire and solder the centre terminals to their appropriate points on the two resistors.
    Thank me later.
    lowell and g1 like this.
  17. #17
    Jan 2011
    NorCal
    251
    Thx, Enzo. That's the schematic I already have--and I'm saying it does not match my board.
  18. #18
    Jan 2011
    NorCal
    251
    Quote Originally Posted by diydidi View Post
    Took your advice. But, since I have new 3W resistors standing tall above the PCB, I just lifted the middle leg of the mosfet out of the PCB and connected it to the leg of the resistor. Didn't solve the issue, though--that resistor (R39) is still dropping 248vDC.
  19. #19
    g1
    g1 is offline
    Feb 2010
    9,884
    Can you post your DC voltages on the Fet connected to R39 ?
    Certified Dotard
  20. #20
    Jan 2011
    NorCal
    251
    Measurements are taken with a 60w bulb limiter in line. R39 gets hot to touch, but doesn't smoke with the bulb limiter in place.
    TR2
    D: 303vDC
    G: 0
    S: 0.6
    TR3
    D: 62
    G: 0
    S: 3
  21. #21
    Dec 2011
    673
    You have to drill the pcb. Its conductive!!
  22. #22
    Jan 2011
    NorCal
    251
    The MOSFET's drain is no longer touching the PCB at all. How will drilling out the hole help?
  23. #23
    Jan 2011
    NorCal
    251
    @diydidi, now I will thank you for your advice! Drilling the PCB would not have helped in my case, because the damage was too widespread. I had to pull C46 out, invert it with leads up, and rebuild the circuit above the PCB. That worked!
    So, thank you!
    The amp is running smoothly and sounds good. Assuming the amp is now operating as designed, R38/39 are dropping 100v each, meaning almost half a watt each. This makes them too hot to touch within the first minute or two of operation. It's no surprise this slowly cooked the PCB, with the original 1-watt resistors right against the board!
    Jazz P Bass, The Dude and diydidi like this.
  24. #24
    Jun 2007
    Pensacola, FL
    3,499
    Have one of these in where TR2 Rd was burnt. Replaced it AND TR2 with IRF830. This amp has STK830 in it. Also replaced C45 because if that was compromised it could have caused the problem too. TR2 Rd is still getting too hot and voltages are incorrect.
    TR2
    D: 42v
    G: 0v
    S: 3.3v
    There is 10k from gate to ground. All components around the transistor test good and are indeed all connected. The Source transistor and diodes are good too. I'm posting now because I've checked everything I see fit to check. Came into the shop because it was crackling and new tubes did not help. So diydid... you seem quite convinced the board is conductive. Has this been something you've fixed more than once and is a common issue with em?
  25. #25
    Jan 2011
    NorCal
    251
    @lowell, is your PCB discolored from heat?
  26. #26
    Jun 2007
    Pensacola, FL
    3,499
    No it isn't
  27. #27
    Jan 2011
    NorCal
    251
    I wouldn't expect it of conducting until it turns darker.
    lowell likes this.
  28. #28
    Jun 2007
    Pensacola, FL
    3,499
    Guess what...drilled holes between the pins. Fixed it. Havent listened for the crackle yet...but the overcurrent is fixed. Both drains have 280v now.
    g1 and The Dude like this.
  29. #29
    Jun 2007
    Pensacola, FL
    3,499
    Completely fixed, crackle gone. I drilled the holes between pins on both PI FETs so it wouldn't come back with the other FET doing it. Never would've thought to do that. So it begs the question, what is wrong with the Blackstar pcb? Or, is it a case of bad pin-layout. IE the pins making a triangle shape on the board would be best.
    diydidi likes this.
  30. #30
    Supporting Member mikeydee77's Avatar
    Mar 2012
    Bristol, UK
    153
    Just fixed an HT-5 with the same fault.
    According to this thread which has good instructions on the repair on the Blackstar Forum it is a common problem linked with PCB made in 2012. On the one I am working on (from 2009) I could not see any sign of a short or scorching even with a x10 loupe but drilling out between the mosfets with a 0.7mm drill bit worked.
    Jazz P Bass and diydidi like this.
  31. #31
    Jun 2007
    Pensacola, FL
    3,499
    Hey guys. This amp is in again. Not sure if same issue. However this is an HT5-C. The BMP amps link no longer works. Would someone pls share the schematic if you have it? Thanks!
  32. #32
    g1
    g1 is offline
    Feb 2010
    9,884
    Here's a couple. If one of them matches the C, let us know which one it is.
    Certified Dotard
  33. #33
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,797
    I noticed that one of the schematics I have has a note from Nick attached to some part of the bias procedure.
  34. #34
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,721
    Quote Originally Posted by DrGonz78 View Post
    You are welcome
    Jazz P Bass and DrGonz78 like this.
  35. #35
    Jun 2007
    Pensacola, FL
    3,499
    It's quite odd. There is no CON1 in this amp. The power tube socket is soldered to the main pcb. So in these schematics... you can see 0v noted between R32/34. But it isn't a ground. This is also the cathode so I'm assuming it SHOULD have a ground/common sign there. I do not get continuity from that point to ground.
  1. Biasing ?
    By chuckb in forum Debugging Your Build
    Last Post: 10-24-2013, 02:09 AM
  2. While biasing a Fender Tremolux (AA763) the biasing is current is increasing?
    By Dandrix in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-23-2013, 09:24 PM
  3. biasing an AC30
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-06-2008, 11:13 PM
  4. Biasing Question
    By lockingnut in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-12-2007, 04:46 PM
  5. Biasing
    By Grubey Doo in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-17-2007, 10:08 PM
