Results 1 to 2 of 2
Thread: Adjustable resistor question
    Junior Member godi's Avatar
    Jul 2007
    Quebec - Canada
    19
    Hi every one.
    I'm starting to build a 5E3 amp and I have tree newbie questions.
    Can I replace the 250 Ohms / 5 watts resistor ( the one that set the bias ) by an adjustable resistor like this on on the picture ?
    http://www.sphere.bc.ca/test/loads2/...-ar10-2500.jpg
    This one is a 2500 Ohm, 10 Watt Adjustable and cost 4.00 $ at :
    http://www.sphere.bc.ca/test/loads.html
    I guess that it is possible to make the adjustment of the tap to be in the 250 Ohms range.
    My second question is : I want to try a choke and see what it does to the tone. I understand that I need to remove the 4.7K/2W (or 5K/2W) resistor and solder the two wires from the choke where this resistor go. Many treads I read say that when a choke is use, it is wise to add a 470 Ohms resistor (or less resistance) on the power tubes. Witch pin number should receive those two resistors on a 6V6 tube ? And what about the other end of this resistor, does it go to the chassis ground or to somewhere else like to an other pin ?
    Third : I did try to solder a 1 Ohm resistor in my Vibroverb clone Bandmaster amp chassis (for easier bias calculation and bias setting) but my Weller 100 Watts iron is not hot enough to make a nice soldering. What kind of tool do I need to solder something on a cold chassis ? Can I simply drill a small hole and screw a Grounding Lug ?
    You can see some pictures of this amp at :
    http://www.jeangodbout.com/vibroverb/clone-1-en.html
    Thank you.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,042
    SOldering to the chassis is hard. One thing it takes is patience, you have to hold the gun on there for a l;ong time. Far easier to mount a ground lug and solder to THAT as you suggested.
    You could use that sort of resistor, but why start with 2500 ohms? You'd never use more than a tenth of it. Get a 300 ohm resistor or something. Imagine trying to change it ten ohms on the 2500? Now imagine ten ohm adjustment on the 300. 10 ohms is spread out a lot farther on the lower resistance part, a lot easier to get the setting you want.
  1. Traynor YGM-3 Add Adjustable Bias
    By Steely in forum Mods & Tweeks
    Last Post: 02-19-2011, 07:19 AM
  2. HIWATT Bias Resistor Question
    By flying snake in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-21-2008, 11:26 AM
  3. Deluxe Electric Mistress resistor question
    By Neal in forum Guitar Effects
    Last Post: 04-27-2007, 07:15 PM
  4. Adjustable Zener circuit.
    By Arthur B. in forum Theory & Design
    Last Post: 10-15-2006, 07:23 PM
  5. Cathode follower cathode resistor question
    By Mark Buckingham in forum Theory & Design
    Last Post: 10-10-2006, 12:12 AM
