Page 1 of 4 1234 LastLast
Results 1 to 35 of 112
Like Tree4Likes
Thread: Les Paul Lo-Z pickups
    Aug 2007
    23
    Hi ~
    nice to see everyone.
    Anyone here have an idea about Les Paul's specs for Low-Z pickups?
    I'd like to know the impedance value of these pickups....
    My understanding is that these were stacked dual coils.
    I'd like to know what guage wire is in these units, roughly how many windings and or any combination of these questions.
    Thank YOU,
    Louie Seven
    Jun 2007
    159
    I haven't worked on one since 1983 so can't remember the dc resistance but it was wound with #28 wire on two stacked coils.
    Aug 2007
    23
    OK! I'm halfway there!
    THANKS!
    Now, the way I figure it, EITHER the number of windings OR the DC resistance in ohms will get me there!
    btw... I should have mentioned that I am aware that some of the Gibson Lo-Z Les Paul pickups are coil tapped and some were not.
    Initially, (1969) the Les Paul Personal and the Les Paul Professional guitars employed Lo-Z pickups without any way to switch to hi-Z for regular amps.
    Kind of an inconvience.
    To rectify that problem, on the Les Paul Recording guitar (1971-79) they installed a hi/low impedance switch...which implies that they went ahead and fully wound the coils for hi-Z and coil tapped them at a MUCH lower value for the Lo-Z function.
    I can't prove it, but it's logical to assume that the Personals and Professionals were not coil tapped and probably had considerably less windings than the Recording models.
    Of course, the Lo-Z pickups that Les Paul hand-wound for his guitars back in the early 50's (the ones that he used to achieve all those amazing tones you hear on the Les and Mary hits on Capitol) were almost certainly not coil-split, (although some probably were, knowing Les) and the early ones were probably crude.
    As the story goes, when Gibson and Les struck up their endorsement deal in 1952, he said, "I'll give you everything, EXCEPT my sound". What he meant was, I'll give you everything except Lo-Z pickups.
    By 1968 he was willing to do that, and Gibson soon issued a succession of guitars and basses with Lo-z pickups.
    Unfortunatley, it seems like only Les and Gibson know the real specs on those pickups. Gibson probably doesn't even know much more than what Les doled out to them.
    Anybody have Les Pauls phone number? *haha*
    I know you can buy off-the-shelf Lo-Z pickups from various mfgs....like EMG...
    but I'm betting they don't get the same sound as what Les Paul was getting.
    The reason I say that, is because EMG is marketing to players who want rock and contemporary sounds. Nobody wants the 'real' Les Paul sound ( I refer to Les Pauls recordings, not the Gibson Les Paul guitar, when I say that).
    Thanks for listening..... I'm still interested in any input, or fragment of knowledge regarding this topic.
    Regards,
    Louie Seven
    Jun 2007
    159
    Louie, from what I remember the pickups were the same, they added a line matching transformer to give a hi-Z out.
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,945
    I posted this somewhere in another thread. Les originally took the coil from an electric clock, which was round, and bent it into the oval shape of the pickup. I'm assuming this is where the idea of using such heavy wire came in. That was the pickup in "the Log."
    On the '71 Triumph bass, the top and bottom coils each had four wires (red, blue, green & orange). I have the schematics from the guitars, but little is known about the pickups!
    I'd love to get some to play with. If we knew the DC resistance, we sould deduce the number of turns... we know the diameter of the pickup, but we have no idea about the core size.
    The volume control on the Recording guitar is 2.5K! The treble control is 1K and the bass control is 2.5K.
    Two things to consider ... you can't wind that much 28 gauge wire on a bobbin, and they probably used large cobalt steel magnets.... but who knows!
    Lo Z pickups are my thing. You don't need much wire on a Lo Z pickup. I'd make up a coil form, get some 28, and see how much you can wind. Don't be surprised it the pickup reads out under 500 ohms.
    As a reference point, the early Alembic pickups used 40 gauge wire, and had 1,000 to 1,500 turns.
    EMG pickups don't have low impedance coils, nor do they sound like it. They are high impedance coils with a buffer amp. So yeah, they sound like high Z pickups with more top end.
    http://coneyislandguitars.com
    the IMmoderator DrStrangelove's Avatar
    the pines country, Tejas
    251
    Quote Originally Posted by Louie Seven View Post
    Only a little.
    Les Paul's Low-Z pups from the 70's were supposed to connect directly to a 600 ohm studio board,or so I mis-recall.
    This means a 600 ohm impedance at 1000 Hz, not a 600 ohm DC resistance.
    If the DCR is 500 ohm using #28 AWG, we can make a few guesses about the core size and estimate the windings accordingly.
    If anyone has a spare pickup that could be X-rayed, so much the better.
    -drh
  7. #7
    Apr 2007
    452
    Here is a nice website on the Les Paul Recording
    http://www.ntw.net/~w0ui/family_webp...lrecording.htm
    Here is a schematic of the inside of the guitar
    http://www.guitar-parts.com/images/lespaul.jpg
  8. #8
    Aug 2007
    23
    Quote Originally Posted by DrStrangelove View Post
    Only a little.
    -drh
    Do I understand correctly that you're suggesting the pickups are approximately 500 to 600 ohms DCR?
    Regards . . . Louie
  9. #9
    Staten Island, NY
    10,945
    Only a little.
    -drh
    OK, just to be clear.. I said "don't be surprised if the pickups are 500 Ohms" ... I'm only saying this because I have no idea what the DC resistance is. But judging from the value of the pots, and the gauge of the wire... it makes sense.
    Now the mixer input makes even more sense.
    So they are probably about 500 Ohms.
  10. #10
    Staten Island, NY
    10,945
    Yes. Low impedance. Might even be 300 Ohms. Who knows. But low like that.
    The very first pickup I wound was a P bass pickup, with 500 turns of 42 on each bobbin.
    You need a transformer, or even better, a preamp. Then they sound fantastically clear. Very smooth and bright.
  11. #11
    251
    resistance ohms are not impedance ohms
    A coil with a 600 ohm IMPEDANCE means that its DCR must be lower.
    For example, loudspeakers are rated at 8 ohms impedance (a 1000 Hz) but have a DC resistance around 6 to 6.5 ohms.
    Ohms are used for both DC resistance and impedance, but they are not the same.
    Joe Gwinn can explain this a bit more clearly.
    -drh
  12. #12
    dpm
    dpm is offline
    Senior Member dpm's Avatar
    Sep 2006
    Brisbane, Australia
    147
    I worked on one of these a year or two ago and did take a DC reading back then but I never wrote it down. I have a distinct feeling the reading was about 500 ohms, though there's no way I can guarantee that and I could be totally wrong. I'll try to remember to check at work to see if anything did get scrawled somewhere....
  13. #13
    Boston, MA area
    2,602
    It's true that in a passive system (no amplifiers) the AC resistance cannot be smaller than the DC resistance, by conservation of energy. Each kind of resistance represents an independent energy-loss mechanism. You can minimize energy loss, but you cannot make energy loss be negative (which would be energy gain).
    With things that are intended for wideband use, unless it's a transformer, the AC resistance woun't be too much higher than the DC resistance, because the variation would cause the spectrum to be shaped.
    In a pickup, we often want the spectrum to be shaped. But in a pickup intended to be flat, not coloring the sound, AC resistance cannot be too much larger than DC resistance.
    In a transformer, the coils have very low DC resistance, and a primary inductance sufficiently high that the reactance at the lowest frequency of interest is at least five times the largest expected AC resistance, and what one is seeing as AC resistance is the load on the other side of the transformer.
    The simplest way to see this is to take a 1:1 audio transformer. Small and cheap is OK. Hook the LCR meter to one winding. With the other winding open, measure inductance and AC resistance. One will measure the primary inductance and AC resistance being the sum of the coil's DC resistance plus something for losses in the transformer itself. Short the other winding. One will now measure the stray inductance of the primary winding, plus a slightly larger AC resistance. Connect a 10,000-ohm resistor across the other winding. One will now measure stray inductance plus AC resistance of about 10,000 ohms. In other words, the LCR meter is measuring the resistor through the transformer.
  14. #14
    Dec 2006
    Philadelphia
    177
    Interesting topic. I have a Les Paul Professional and I have the Les Paul Bass pickups in my 1971 Jazz bass. The LP professional is two inches wider than a regular LP. I had to get a four inch wide strap so I could play it standing up. The LP Recording came out as a reduced cost model during the Nixon era price controls. Manufacturers couldn't raise prices on an existing models so they came out with models cheaper to make at the same or higher prices. It was much cheaper to assemble the controls on a plastic plate then to mount everything through the wood in the case of the LP recording. I had a friend who owned the LP Personal and that had a built in three pin mike jack on the upper bout. Good for solo work I guess. They also put a gold plated version of these pickups in some of the Gibson L5 S models. Another heavy solid body.
    The Bass pickup is the one with the multiple coil taps. It has Three taps for a total of eight wires from the pickup and the bucking coil. I bought the 71 Jazz bass new in 71 just to put in the LP pickups. It went right from the store to the routing table. I still have it and it sounds fantastic.
    I bought my LP Pro in 1973, but I had already been making my own low impedance pickups before that. I used ceramic bar magnets I got from Edmund Scientific and wound the bucker coil on an extra piece of steel that came with the magnets. I think I used #30 or #32 wire. I used what Gibson used to match the pickups to the amp, a Shure inline mic transformer. It worked best jumpered for 50 ohms. I molded the pickup assembly into a clay like substance that got baked in an oven at around 200 deg F.
  15. #15
    Aug 2007
    23
    Quote Originally Posted by J Martin View Post
    WOW! that's quite the info! Wondering if you'd be amenable to measuring the DC resistance of the pickups on your Lp Professional for me ? I'd be truly appreciative.
    And btw, did you create a stacked hummer or a side-by-side hummer?
    The Gibsons are stacked. But if a guy wanted to create Lo-Z pickups to install on a conventional Les Paul guitar, he'd want them to resemble conventional Humbuckers..dimensionally, that is.. so they fit the cavities without more routing etc...
    Also, am I understanding that the Lo-Z pickups that you wound were about 50 ohms? (you mentioned that the Xformer worked best at that range)
    THANKS, Louie Seven
    thanks to everyone else too........this is very informative.
  16. #16
    Staten Island, NY
    10,945
    Come on, spill the beans! Seriously though, can you give us a DC resistance reading on the pickups? I have never read anything about them anywhere.
  17. #17
    Dec 2006
    Philadelphia
    177
    I measure the DC resistance at 9.5 ohms. Fortunately I have a second LP Professional that is already disassembled waiting for restoration so I didn't have to take the player apart. I think that the pickups I made were even a little lower in resistance. I used side by side coils. I just made them using my intuition of what I thought low impedance electronics should be. I was inspired by Alembic at the time although I had never examined any of their pickups.
    Generally you won't get enough magnet mass to be able to fit a low impedance pickup in a humbucker route. There is only one person I knew that made a workable LI pickup in the humbucker form factor and that was Tom Doyle from North Jersey. I believe he may actually have a patent on them. It was hush hush back in the 70's around his shop. His pickups, I believe, were higher impedance then the LP pickups because they were hotter and smaller, but still fell within low range. Its a compromise as usual.
  18. #18
    Jun 2007
    159
    9.5 ohms? Was that at the coil or the transformer? That sounds too low.
  19. #19
    Dec 2006
    Philadelphia
    177
    The measurement was taken with the pickup loose on my bench. The Professional has no transformer, btw. Its only in the recording. Not too low, its in the speaker range. Don't expect a 1:1 transformer match. We are in the millivolt range.
    #28 AWG is 66.11 ohms/ 1000ft. #30 AWG is 105 ohms/1000 ft., # 32 AWG is 167.2 ohms/1000 ft, at 68 degrees F.
  20. #20
    Jun 2007
    159
    With that kind of low-Z what preamp or amp do you use? Or were they intended for direct recording?
  21. #21
    Dec 2006
    Philadelphia
    177
    Sorry I wasn't clear about the transformer. The LP recording has an internal transformer. The LP Pro has an inline, mic type transformer. It works with any regular guitar amp. You can use a 200 ft. guitar cord with the transformer at the amp end, if you want. Very low losses.
  22. #22
    Aug 2007
    23
    Smile
    ~~~~~~this is good!~~~~~~~~
  23. #23
    Jun 2007
    159
    I'll have to say that's the lowest low-Z I've ever seen. Anyone else making low-z pickups that low? I would think anything below 1k would be considered low-z.
  24. #24
    Apr 2007
    452
    I was wondering if you didn't mind measuring the resistance of the other pickup just to verify this doesn't have shorted turns.
    Thanks
  25. #25
    Aug 2007
    23
    Well....... in a twisted turn of luck, I surfed into a German site about THE LES PAUL RECORDING GUITAR. A translated version of one paragraph follows (it's possible that the non-translated original text is more decypherable *haha*:
    For electronics Freaks: The Pickups has a resistance of only 10.8 ohms - round a thousandth of what one knows otherwise in such a way. Their inductance - the actually crucial size - is 8 mH. The frequency response is ruler straight and is enough until far over 200 kHz. This concerns “coaxial” Humbucker so mentioned, i.e. with two coils, which sit one above the other. Like that the decrease is limited to a very short piece of the string, so that one kriegt hard heights as with a normal single Coil Pickup; but nevertheless it does not hum, if one comes the amplifier too close. The Pickups is filled and practically indestructible with epoxy resin. They do not hang on three screws and wackeln thereby.
    So........ that's interesting. I'll let the engineers here sort it all out, technically I mean. I guess no one will ever know what kind of slugs are in those things without cutting one open or Xrays. As regards these options ...the former is draconian, the later is expensive.
    ANYWAY....... here's a link. http://translate.google.com/translat...l%3Den%26lr%3D
  26. #26
    Staten Island, NY
    10,945
    Wow, much lower than I expected!
    my pickups are practically high impedance by comparison!
    I guess it makes sense, if a 8K pickup has a 250K or 500K pot, a 10 ohm pickup would have a 1K pot.
  27. #27
    3,987
    The coil is really only a small part of the recipe. The magnets in those things were clearly VERY different from what we're used to around here. Unfortunately, with the pickup seemingly epoxied it was hard to tell what the magnet form/type might have been. All I know is that that sucker was heavy and the magnet much stronger than any single coil I've ever come across.
  28. #28
    Staten Island, NY
    10,945
    I seem to remember reading they were cobalt steel magnets, like the kind they used in the original CC pickup. Big ass magnets.
    I doubt you need one of those though, unless you just want to replicate the pickup. having a metal core helps to bring up the inductance, which will give you more output. You don't have the usual problems with inductance messing the highs up because the coil is so low resistance.
  29. #29
    Aug 2007
    23
    Quote Originally Posted by David Schwab View Post
    The Gibson circuit diagram indicates 25K pots...for whatever that's worth.
    Louie
  30. #30
    Staten Island, NY
    10,945
    Not on the schematic I have. I have one for the Triumph bass, but that doesn't list values. That's an actual Gibson schematic. The one for the recording guitar is hand drawn, and list the values. I meant to say 2.5K also.
    I got these back in the 70's from a Gibson repair center. They are photocopies, and I colored in some wires and marked the controls in red to make it easier to read.
  31. #31
    Aug 2007
    23
    hi
    2.5K is correct.... my mistake...the diagram I have is very blurred..but upon close examination, there is indeed a decimal point.
    I surrender to superior forces!
    NOW, I have a theory question...it's a general question about stacked coils. Nothing really to do with Lp Recording guitars or low impedance....
    IF a person took a standard humbucker and cut it in half...(seperating the coils, as it were) leaving all the wiring and connections intact, and then positioned one coil atop the other (assuming that all other practical considerations such as cavity depth, pickup mounting, etc, were dealt with properly)...would this arrangement work?
    Opinions ?
    Louie
  32. #32
    Staten Island, NY
    10,945
    From my limited experience with stacked coils... the problem is either the bottom coil is a dummy, and that makes the sound weak in the upper coil, or the bottom coil senses the strings, but then it's out of phase, so it cancels low end.
    Duncan stacks have the magnets going through both coils, so the bottom coil is active. I made a Tele lead pickup like this. Very bright sounding, but in a good way. I could have wound a lot more wire to help this. You may notice that stacked pickups usually are wound pretty hot.
    Dimarzio and Kinman have a dummy coil on the bottom, with a magnetic shield between them, and the bottom coil has no magnets, but does have metal slugs for increased inductance.
    I'm not sure how EMG and Bartolini have the coils/magnets set up... But EMG gets around the dummy coil issue by using a summing amp, and thus isolating the active coil from the load of the dummy. Alembic does the same thing.
  33. #33
    Aug 2007
    23
    It's clear that I'm going to be doing a bit more research before I tackle this.
    Yep!
    But hey, a thousand feet of 28 or 30 will allow me two or three shots at it.
    eh ?
    Thanks everyone.
    Louie Seven
  34. #34
    dpm
    dpm is offline
    Sep 2006
    Brisbane, Australia
    147
    Sorry for the misinformation is my previous post. The guitar I was thinking of was a Les Paul Signature. Those pickups (I'm pretty sure) were either 200 or 500 ohms.... I think more likely 200. Those 2 numbers look so similar on a meter lol
  35. #35
    Aug 2007
    23
    I remember when those Lp Signature guitars first appeared.
    It was, in the early 80's and we were walking down up Van Ness Avenue in the peoples republic of San Francisco.
    Suddenly, there was a music store I'd never seen before. I don't know if it was new, or if I'd just overlooked it....
    At any rate, we strolled in and there on the floor was two blonde Gibsons that looked like strange Rickenbackers. A guitar and a matching bass.
    The headstocks said 'Les Paul Signature'. I just marveled, scratched my head and left.
    L7
  1. Paul Amp made by Pine electronics
    By jaysunhoffman in forum Vintage Amps
    Last Post: 04-13-2011, 04:48 PM
  2. Stellar les Paul copy, any one tried these?
    By Slobrain in forum Guitar Tech
    Last Post: 04-25-2009, 01:49 AM
  3. My Les Paul Forums
    By Spence in forum Pickup Makers
    Last Post: 09-06-2008, 08:19 AM
  4. PBS TV Special tonight on Les Paul!
    By TD_Madden in forum Lobby
    Last Post: 07-13-2007, 07:02 PM
  5. Les Paul DYI PreAmp/Amp Orientation
    By distortion30 in forum Guitar Amps
    Last Post: 05-23-2007, 05:30 AM
