Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 08-04-2007, 11:49 PM   #1
PT & OT specs for Hot Rod Deluxe?
Does anyone know the voltage and amperage specs for the Hot Rod Deluxe transformers?
Voltages are easy enough, but I have not found any thing about listed specs, and do not have the means to measure amps.
I read a thread recently about someone who took their Hot Rod Deluxe and converted it into a Plexi. Gutted circuits and dropped in his own. Got me thinking. I have a Marshall 800 and a HiWatt 50W amp I am wanting to make, and this seemed like a good approach. Probably the HiWatt, only requires one extra hole for a 12AX7. Wanting to see if the existing PT will work for this project.
thx
Stanz is offline   Reply With Quote
Old 08-09-2007, 09:55 PM   #2
hi
These pfd have the specs of fender amps transformers:
http://w13.easy-share.com/2952271.html
Frankli
Frankli is offline   Reply With Quote
Old 08-10-2007, 06:59 PM   #3
Fender Original Hot Rod Deluxe Power Transformer. Equivalent to #036958.
Primary: 117 volt, 60 Hz
Secondary: 440VDC, 65.7 mA after rectification
Filament winding 1: 6.6 VAC, 3.75 A
Mounting Centers: horizontal
Weight: 4.3 lbs
Also have a look on The Fender Forum and http://studentweb.eku.edu/justin_hol...s.html#dealers
You might - with a bit of jiggery-pokery get away with the PT but the OT's 40W - they're meant to be pretty tough but I personally wouldn't try and shove any more than that through it - not on a regular basis anyway - I'm building a Bassman clone outta my HRDv remains - have a look...
http://images.lilypix.com/albums/use...A-Dv_schem.jpg
http://images.lilypix.com/albums/use...F6A_layout.jpg
Seriously though - the guys at the Fender forum are pretty helpful - good luck!
yankeerob is offline   Reply With Quote
Picture of new 57 Deluxe vs original Deluxe Gee 5 E 3 7 06-12-2007 03:25 PM
1965 Deluxe tube specs Alexandre IV Maintenance, Troubleshooting & Repair 9 06-01-2007 05:14 AM
Anybody mod their VC to tweed specs? steel1953 Harp Amps 3 02-23-2007 10:43 PM
Exact PAF specs anyone? Possum Pickup Makers 13 11-28-2006 05:53 AM
5F4 P/T Specs? Watto Tweed Builders 0 07-25-2006 09:40 AM
