Old 08-08-2007, 02:08 PM   #1
Hiwatt with no sound
I just bought a hiwatt 50W lead model SG-50.Kind of an odd ball and I can't find a schematic for the preamp section.I have rebuilt the bias supply and put in a MM output transformer.All of the voltages seem to be fine in the power supply but I have no sound.Checking voltages in the preamp section they all look good with the exception of 1VDC on pin 1 of V2.
I get some signal thru the speakers when using a signal generator but none with a guitar plugged in.Any ideas?
TIA
fiesta55 is offline   Reply With Quote
Old 08-08-2007, 03:31 PM   #2
1VDC on a 12AX7 plate sounds like a bad thing, open plate resistor? Check value.
MWJB is offline   Reply With Quote
Old 08-08-2007, 06:15 PM   #3
Thanks.It was an open plate load resistor.But I still have a problem.I'm not used to resistors with 4 color bands.The one I took out was Red,Red,Black ,Orange which I assumed was 220k.I replaced it with a 220k and now have a high frequency ocsillation.All of the preamp tube sockets are fairly microphonic.Did I use the wrong value?
Old 08-08-2007, 11:38 PM   #4
Mars Amp Repair's Avatar
I believe that your resistor would read 22.0 K ohms. The extra band (black or '0' in your example) allows a more refined value to be displayed on the resistor.
Though, I do agree that 220K seems more like what we're used to seeing in the plate position. glen
Mars Amp Repair is offline   Reply With Quote
Old 08-09-2007, 12:54 AM   #5
Can anyone confirm the 22.0k I found a resistor code calculator on line for a 4 and 5 band code and it says it would be 220k.
Old 08-09-2007, 01:50 AM   #6
oh yeah...that's correct...I got the decimal in the wrong place...if it were red-red-brown-orange...it would be a 221K...sorry for error....glen
Old 08-09-2007, 07:12 AM   #7
220k.
Even if the 3-4 color band thing was confusing, you would not likely see a 22k plate load on a 12AX7 in a guitar amp, while 220k is perfectly reasonable.
A lot of newer resustors are close tolerance, so they added an extra digit band, which means the multiplier band would be one less. Thus 220k is 2-2-0-000, instead of 2-2-0000.
Tube swap on Hiwatt davoux Maintenance, Troubleshooting & Repair 11 07-25-2008 01:49 PM
Hiwatt Lead 50 bias reistor tonezoneonline Maintenance, Troubleshooting & Repair 7 04-25-2007 04:08 PM
Hiwatt SG50 Lead tonezoneonline Maintenance, Troubleshooting & Repair 0 04-18-2007 09:31 PM
Custom Hiwatt 50 power supply Euthymia Maintenance, Troubleshooting & Repair 6 01-03-2007 07:45 AM
Hiwatt output weak Guitarist Maintenance, Troubleshooting & Repair 2 07-28-2006 11:51 AM
