Results 1 to 6 of 6
Thread: Rattle in new Fender Blues Deluxe.
    Jul 2007
    9
    Hi, I got another question about my 1 and a half week old Fender Blues Deluxe Reissue. There's a fairly moderate rattle coming from the amp when I play. The rattle is stronger at some frequencies then other. I went down to the store with it and asked them, but they said it was completly normal, that all tube amps occasionally gives off this sound, and it was nothing to worry about. I don't really think it's a seriouse problem, but I just want a second opinion. Thanks in advance!
    Edit: Just to discribe the rattling sound better I'd said it sounds like as if something is loose inside the amp. Like a metal piece of some sort. Someone discribed it once as the sound a lightbulb makes when it's done (you know with the string inside it). Of course, I've checked if all the tubes are ok, and they are.
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    810
    Is the rattle also coming through the speaker?...if it is that's called 'microphonic' and could also could make a vibrating sound right from the tube, too.
    You could rearrange the 12AX7's to get the noisey one in say the driver location. It probably wouldn't be as micrphonically noticeable there. IF the tube is vibrating internally of course it would need to be replaced.
    If it is a physical vibration, sometimes you can just pinch the tube with thumb & forefinger & that will silence it indicating that is the culprit. Watch out for heat! Also just tapping the tube with the handle of a screwdriver can bring out the vibrating culprit.
    Power tubes can also be microphonic, but ususally with older ones.
    We have also noticed that for some louder vibration issues with this style of amp, all y ou have to do is tighten the chassis mount screws that are on the side rear of the amp & lots of vibration will go away.
    glen
    Jun 2006
    Norristown state hospital
    910
    Try taking the chassis out or using another speaker to try and isolate the problem.
    I had a cheaper SS Fender combo that would vibrate and cause weird oscillations, like one of the components was vibrating and the noise was being amplified.....didn't bother fixing as it wasn't worth it..
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,042
    NO. Don't do anything to it. It is a brand new amp with an issue. That is what warranties are for. Take it to the nearest Fender repair station for warranty repair.
    Sep 2006
    Englewood, CO
    810
    All those things I suggested could still be attempted without opening the amp or voiding any warranty OR having to wait for the service center to get to your amp.
    If it ends up needing a new tube, Fender covers them for only 30 days, so don't wait too long to make up your mind.
    glen
    18,042
    You are right Glen, but when you find the microphonic tube, you still have to take the amp in for the replacement. The service center won't just hand you one. And what if he breaks a tube? I'm just anal about these things.
  1. Blues Deluxe channel Limbo
    By pabothecat in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-06-2010, 12:56 AM
  2. Fender Blues Junior Harp mods
    By Watto in forum Harp Amps
    Last Post: 12-25-2008, 05:32 PM
  3. Hum in my fender blues de luxe
    By siggo in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-06-2007, 10:57 AM
  4. Blues Deluxe Channel Problem
    By eeijcon in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-16-2007, 10:16 PM
  5. Fender Blues Jr Noise
    By Mark Black in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-09-2007, 07:03 AM
