Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 08-10-2007, 11:53 PM   #1
PT current rating Q
I need someone to point me to an "Idiot's Guide to Power Transformer Ratings." I don't get why secondary current rating is given in DC. Unless I'm totally mis-imagining how a power supply works, it seems to me that the current in the transformer will be anything but DC, i.e. in a half-wave supply, each half of the winding is only supplying current during the portion of the cycle that it's voltage is higher than the first filter cap, no?
Is it just that they've done the math for you, assumed a capacitor input load, and are saying if your load draws this much, the transformer will handle it?
Ptron is offline   Reply With Quote
Old 08-11-2007, 10:36 AM   #2
Quote:
In two words: that's right. AC ratings are for those who can do the math themselves as going back and forth between avarage, rms and dc can be confusing at times.
__________________
Aleksander Niemand
Tubewonder amps
Life's a party but you get invited only once
Alex/Tubewonder is offline   Reply With Quote
Old 08-11-2007, 12:22 PM   #3
Supporting Member
Steve Conner's Avatar
Straight answer: Yes, they did the math for you.
Slightly more geeky answer: Average current is what forms the DC output to the load, but RMS current is what determines the heating in the transformer.
So, the difference between the transformer's AC and DC ratings is determined by the RMS-to-average ratio of the current waveform. That depends on the type of rectifier topology (bridge or FWCT), the type of filter circuit, the size of the filter capacitor(s), and a bunch of other stuff like resistance and leakage inductance of the PT.
So it's easier for the manufacturer just to do the math for you (but bear in mind that if you use a greatly different value of filter cap, the answer won't be valid any more: the bigger the cap, the lower the DC rating will be)
BTW, if you ever wondered why a transformer for a tube rectifier is so much bigger and heavier than one for a solid-state bridge of the same DC rating, now you know.
Steve Conner is offline   Reply With Quote
Old 08-14-2007, 01:53 AM   #4
Thanks guys. That's the info I was looking for.
I assume that's either common knowledge or a natural assumption that's eluded me ( wouldn't be the first time ) as you would kind of need to know that when selecting a PT.
max. uF rating NOS 5Y3GT Chris / CMW amps Theory & Design 5 02-07-2008 09:09 PM
Power rating for Inductors Scorpion Music Electronics 6 07-25-2007 04:10 PM
Capacitor voltage rating Don Maintenance, Troubleshooting & Repair 3 06-19-2007 02:08 AM
Impedance Switch Current Rating? Yossarian Theory & Design 2 10-21-2006 07:36 PM
PT current rating for 6L6 in Brown Princeton pete_b Tweed Builders 2 06-13-2006 09:31 PM
