Results 1 to 26 of 26
Like Tree9Likes
  • 2 Post By g1
  • 1 Post By oc disorder
  • 1 Post By g1
  • 1 Post By Archie Speed
  • 1 Post By g1
  • 1 Post By Chuck H
  • 1 Post By eschertron
  • 1 Post By Chuck H
Thread: Jtm30 output tubes not lighting up?
    Jan 2009
    586
    Hi All
    I just popped over from the pup makers forum. I have a question . I lent my Jtm 30 combo to a friend and he just told me that after a month the amp stopped working. The main tube were not lighting up. I haven't had the amp back yet to check it out but was wondering if the output transformer might have blown. I realise that with such limited info it's hard to make a diagnosis, but I thought I would enquire before I get the amp back to check out.
    Cheers
    Andrew
    Jun 2006
    California, USA
    3,455
    Tube heaters being off (If that even turns out to be correct) is not a symptom of a blown output transformer. You just need to wait until you have the amp so you can do first hand troubleshooting.
    g1
    g1 is online now
    Feb 2010
    9,853
    The JTM30 has an internal fuse for the heaters (F101).
    Attached Files Attached Files
    Chuck H and Alan0354 like this.
    Certified Dotard
    Old Timer oc disorder's Avatar
    Jul 2006
    Land Down Under
    1,268
    Waldo .. there is a T6.3amp fuse internally for the heaters, (the filaments) which is what you see glowing.
    Usually it (the fuse) blows for a reason eg the output tubes/valves are kaput !
    In this situation I wouldn't even consider fitting a new fuse until the two output tubes are replaced.
    Regarding the output transformer ... Last time I contacted the Marshall agent here in Aust. I was told they were no longer available
    and that was at least 5 years ago. As Tom has pointed out no glow in the tubes doesn't mean the output transformer has blown.
    BUT if there is a serious problem with the o/p tubes and you refit the fuse you may find within the first few seconds you have just burnt out your transformer.
    The fuse is one of the smaller ones M205 (5mm x 20mm) and a slow blow or timelag as it has a "T" before the amperage-T6.5 amps.
    A non timelag would probably go open circuit with an initial cold switch on with the high current surging through the cold filaments.
    Incidentally the pre-amp tubes also depend on this fuse , and as they operate on a DC supply , a bridge rectifier is connected after the fuse .
    It's harder to see the pre-amp tubes glowing due to the design of the tubes and also when the amp is in the cabinet.
    Good luck and maybe your friend could chip in towards the replacements.
    Chuck H likes this.
    g1
    g1 is online now
    Feb 2010
    9,853
    What kind of power tube fault could cause failure of the heater fuse? Heater to cathode short?
    Certified Dotard
    Oct 2011
    1,951
    My JCM 900 blew the HT fuse for no apparent reason too!!! I troubleshoot all the way to the fuse and found no problem. Replaced the fuse and was good to go. Don't ask me why.
  7. #7
    g1
    g1 is online now
    Feb 2010
    9,853
    Sometimes they blow from the turn on surge, especially if the line voltage is high. I recall one of the JTM models was prone to this and sometimes needed a little bit of over-fusing on the heaters. But I believe it was the JTM600 which had EL34's drawing more heater current.
    torcamaniac likes this.
    Certified Dotard
  8. #8
    Jan 2009
    586
    Hello All
    Well I got in touch with my friend who had borrowed the amp and guess what,? he had flipped the standby switch to quickly before the valves had a chance to warm up DUH!!! . So anyway thanks to all the people that responded.
    All the best
    Andrew
  9. #9
    Jun 2006
    California, USA
    3,455
    Quote Originally Posted by the great waldo View Post
    ...he had flipped the standby switch to quickly before the valves had a chance to warm up DUH!!! ...
    That should not cause a problem unless he continued to flip the SB switch multiple times in quick succession.
  10. #10
    Oct 2011
    1,951
    That could not cause the problem.
    But I am not surprised it blew for no reason either. Look at the big tubes, make sure it's not glowing on the side( the greyish metal), if it's not glowing in the dark, and let it go for now.
  11. #11
    Jan 2009
    586
    Quote Originally Posted by Alan0354 View Post
    Hi Alan
    There was actually nothing wrong with the amp. It was just that he wasn't waiting long enough for the amp to warm up !! It reminds me of a customer who bought a Martin acoustic guitar in for a setup, the fingerboard was swimming in lemon oil. I mentioned to him that he shouldn't oil the fingerboard as it was made out of plastic (corian or whatever martin are using these days) but we saw the funny side of it.
    Cheers
    Andrew
  12. #12
    Sep 2010
    Florida
    891
    It's a different application, but after years and years of hvac work I've learned to accept nuisance over current tripping as just that, a nuisance. If I come across a blown fuse or tripped breaker, I perform simple checks to rule out grounded or resistive shorts, replace or reset the protection, and move on.
    ~Semi-No0b Hobbyist~
  13. #13
    Mar 2014
    61
    FWIW...I worked on a JTM60 recently that blew it's T6.3A fuse at random intervals. Replaced the bridge rectifier, floated it a bit higher off the pcb than stock in an attempt to get better airflow/cooling & no more problems.
    These amps have the bridge rect & main filter caps nestled amongst a few cement block 5W resistors, all of which sit directly over the horizontally mounted power tubes. Warm in there. Just a thought.
    Archie
  14. #14
    g1
    g1 is online now
    Feb 2010
    9,853
    The JTM60's have EL34 which draw much more heater current than the 5881/6L6 of the JTM30. As a result they are much more prone to blowing the heater fuses.
    I seem to recall they were blowing during operation rather than at startup, so it may be heat related as you mention.
    Thanks for the tip Archie.
    Certified Dotard
  15. #15
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,180
    Hi Alan
    Cheers
    Andrew
    So is that to say that the amp is working correctly? No blown fuses and heaters are warming correctly? How long did the guy wait to see if the tubes were glowing, like two seconds?!? The tubes will show a glow after only a few seconds. Standby has nothing to do with the heater supply. Just sayin'. This got confusing and mislead somehow. And more importantly...
    Are you saying that Martin is using Corian instead of wood to make fingerboards?!?
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
  16. #16
    g1
    g1 is online now
    Feb 2010
    9,853
    Quote Originally Posted by Chuck H View Post
    Some models are using something called "richlite", which doesn't sound like it would soak up much oil.
    Chuck H likes this.
    Certified Dotard
  17. #17
    May 2007
    pacific north west
    13,180
    I dunno... I certainly don't know as much about how to make a guitar as the good folks at C.F. Martin, but I'm still partial to wood under my fingers. I like this even less than the resin backs on Ovation instruments.
    "Yeah, I got the new Martin with the latest technological advancement. A recycled paper and plastic resin fingerboard!" I had to write this to see what it might look like since I don't expect anyone else is ever going to.
    Richlite - Wikipedia, the free encyclopedia
    g1 likes this.
  18. #18
    Aug 2012
    Great Black Swamp
    1,730
    If the cellulose component of the richlite is sawdust from rosewood or ebony cutting operations, then the maker could advertise the fretboard is made "from" that exotic tonewood.
    When I saw the word "richlite" I thought it referred to people who'd buy a Martin just to say they had one.
    Justin Thomas likes this.
    If it still won't get loud enough, it's probably broken.
    We need more chaos in music, in art... I'm here to make it.
  19. #19
    Mar 2014
    61
    Richlite is just the neck. It gets deeper when you look at the 'High Pressure Laminate' used for the back & sides of some models. I saw one smashed in & it sure looked like Formica. Maybe old growth Formica....
    Archie
  20. #20
    Dec 2008
    Wernersville, PA
    12,143
    This article states that the 'fingerboard', at least on the OMC-160GTE, is made of "Richlite".
    Martin OMC-16OGTE Acoustic Guitar Review
    The neck is mahogony.
  21. #21
    Mar 2014
    61
    Martin 'X' series instruments...Richilite fb, Stratabond neck (hardwood ply) and HPL sides & back. An effort at cost cutting & sustainability. Different. Play & sound? Don't know 1st hand, but Martin put their moniker on them,so I'm betting they are ok.
    X Series | C.F. Martin & Co.
  22. #22
    May 2007
    pacific north west
    13,180
    I'm sorry, but if I'm spending 800 bones on a guitar it'd better be made of WOOD. I'm just trying to wrap my head around this as a reality! "C.F. Martin is making guitars from laminated scrap wood, paper pulp epoxy resin and photo finished Formica. This is disgusting, 90's Gibson like behavior and I hope no one buys these. Too late for a save though. Once you go there you can never get all the way back. Martin is surely facing some tough times. since the market for top end manufactured instruments is in the tank and there are highly revered custom makers that are only about 25% higher than their top line products. I understand their consideration to target a different demographic. This though, for me, just takes a crap on the prestige of their whole product line. Probably because they have the nerve to set the price relative their reputation. So I have to make the consideration that decisions on the construction of their higher end instruments are also made by the same people. I'm just not putting my money in those hands.
    Sorry... Rant over.
    EDIT: I just had a minor secure! In their top line products they now offer a "John Mayer" model for 10k
    Maybe I should grow a thicker skin but I feel like one of my childhood hero's died
    g1 likes this.
  23. #23
    g1
    g1 is online now
    Feb 2010
    9,853
    Yeah! Even Esteban guitars are made from "real wood" .
    Certified Dotard
  24. #24
    Aug 2012
    Great Black Swamp
    1,730
    I'm not defending Martin on this, but to make an instrument out of real live wood, with all its imperfections and variation, takes a whole lot more time and effort simply to control quality in the build. Synthetics? Easy. Press the button and watch the gauge as material is carried down the production line.
    I'm suggesting that there's no other way to get a consistent quality product in the price gap from U$200 to U$2000. Either the production quality suffers due to inconsistencies, or the aesthetic quality suffers due to alternate (some may say inferior) materials.
    Perhaps Martin could have marketed these as the 'economy' line guitars, branding them differently the way Fender/Squier or Gibson/Epiphone does?
  25. #25
    May 2007
    pacific north west
    13,180
    I do know a little about the inconsistency of wood and the perils it poses to the end product. I understand the appeal of synthetic materials. There's something else in play here. What I'm saying is that if Takamine, made a guitar from these materials it would cost $250 and sound/play about the same, cause, well, the materials are consistent. But if Takamine made a guitar from these materials with a correspondingly appropriate price everyone would instantly brand it a cheap turd made of chip board and plastic.
    I'm not even considering any "hand made" aspects. Since only the more expensive premium guitars feature a herringbone inlay I have to wonder how they can offer it on select cheaper models. CNC? Made overseas and only assembled here? Something is amiss and Martin is charging a premium for a product that has about as much to do with their craftsmanship and reputation as that Takamine (except the Takamine probably has more actual hand built construction). I'm not saying you shouldn't make a guitar from synthetic or recycled materials with CNC construction. I'm saying Martin shouldn't. Especially if their going to price them in the "Stop! You're tearing me!" range.
  26. #26
    Jan 2009
    586
    Hi Chuck
    The amp is working fine, I think he just panicked when he got no sound out of the amp straight away, 2 seconds was probably right and might have even had the volume turned down as well.!! I have been making guitars for over 30 years now and yes Martin is making fingerboards out of synthetic materials corian or similar, it's all down to making a buck corporate thinking (profit is king) and if you want real wood you'll have to pay through the nose. Set a precedent and away you go.!!! I thought that the standby switch was there to allow the 6.3 volts from the heater supply to warm the Valve plates up before hitting the valves with the full voltage to reduce plate stripping/degragation. I'm afraid i'm not that hot on amps, much better with holz!
    Cheers
    Andrew
  1. Marshall JTM30 mystery
    By scr@tchy in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-23-2017, 10:30 AM
  2. Blues Jr power tubes not lighting up
    By daz in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-08-2013, 04:54 PM
  3. matchless lighting build ?
    By chuckb in forum Debugging Your Build
    Last Post: 02-22-2010, 03:20 AM
  4. jtm30 bias mod problem
    By donegone in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-13-2009, 02:17 PM
  5. New Power Transformer Install Help JTM30
    By amearse in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-30-2008, 02:43 AM
