Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 08-20-2007, 08:59 PM   #1
Installing a Bigsby vibrato arm myself. Safe? Smart?
Hi, to cut to the case, I need a vibrato arm. I could of course just go buy a guitar with one allready installed, but as we all know (too well) guitars are very expensive, doesn't matter how much we want them. So instead I've chosen to install one myself, that is if I have the guts.
Ok, I've got an Epiphone Sheraton II guitar possibly equiped with two TV Classic-pickups (thinking of buying such). I saw a video on YouTube (http://www.youtube.com/watch?v=23DH-uFn6A8) that showed me how to install a Bigsby to a Epiphone Dot Studio, which is more or less the exact same guitar as mine, and it all seemed pretty simple. What I'm more concerned about is if it's such a smart idea thinking of the sound and the fact that I'd be drilling several holes into my guitar as well as leaving two rather big holes, where the last tailpiece would have been, open. So I was hoping you could share some of your experiences doing something like this? Will the guitar stay tuned even after using a self-installed vibrato arm? What about the holes? Will they damage the guitar in any way?
In advance, thank you!
Wiborg is offline   Reply With Quote
Old 08-21-2007, 02:36 PM   #2
Easy enough. Just be sure you measure the position of to-be-made holes MANY times before any drilling, and make sure the drilling device is secured and able to precisely locate the hole. The key thing to remember about Bigsbys is that the roller bar must end up being perfectly parallel with the nut such that any pressure applied with the whammy bar is equally transferred across the strings.
Mark Hammer is online now   Reply With Quote
Old 08-30-2007, 04:34 PM   #3
Pickup Maker
David Schwab's Avatar
Those Sheraton II's are nice guitars once you swap out the hardware. I did one for a guy. He put in Duncan Alnico II humbuckers, new pots and switches, and a new bridge.
Bigsby's aren't hard to install. They attach to the rear of the guitar by the strap button. Usually it's three screws. Just make sure everything is centered, and use a dill with the proper size bit to predrill for the screws.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 09-18-2007, 02:33 AM   #4
It's not hard, you just have to measure right, and get the good Bigsby. The cheaper ones are crap.
A cheaper, and much quicker trem would be to put on one of those "Les Trems". It replaces your tail piece. It's not a Floyd, but a Bigsby isn't either. Off hand, I'm not sure if they measure out the same as an Asian guitar.
Dr. Guitar is offline   Reply With Quote
Installing a fan MitchK Mods & Tweeks 13 11-20-2009 12:17 PM
15w Alnico Blue [safe w/15w ?] petemoore 5 E 3 9 03-02-2008 05:18 PM
When is it safe to work on? ajs Maintenance, Troubleshooting & Repair 1 07-16-2007 01:27 AM
LED installing old SMALL STONE franklyn Guitar Effects 3 05-21-2007 05:12 PM
installing a reverb tank MitchK Mods & Tweeks 3 10-09-2006 06:43 AM
