Is it safe to say that it is a coil within a coil? Is it 2 separate coils wired separately? or is the entire coil connected and you just insert a hookup wire somewhere in the coil and only use a specific section (DCR?) of the coil for the tap?
Per Spences description....using 2 gauges of wire... it sounds like to me they are two separate coils on one bobbin.
Can someone describe how a tapped SC would be wired (i.e. hookup wires to the tapped coils)?
Forgive my ignorance...the single coil tapped thing is new to me.
