| | #1 |
| Lifetime Member Join Date: May 2006
| Cheap, easy beginning coil winder
I was in Harbor Freight today. They're having a sale (as always) but I noticed that this: ![]() was on sale for $30. What made me notice it was the grinding wheels had been stripped off the grinder, and that made me look, and then I noticed the single-knob variable speed control. I think if you took one of these and relocated the knob to a foot pedal, you could just remove the grinding wheels, attach a bobbin holding disk, and have a manual coil winder ready to go for $30, including having a warranty on it. |
| | #2 | |
| Senior Member Join Date: Jul 2006 Location: Detroit, Michigan
| Quote:
| | #3 |
Bummer - you'd have to not only pull off the grinding wheels and shrouds, you'd also have to change the pot out when you put it into a foot pedal for speed control, and also screw it down to something; on top of that, you'd have to try out the one you get and make sure there's no wobble. Everybody, ignore this. It's way too much extra work! it makes a lot more sense to make the whole winder up out of plywood and old sewing machines. |
| | #4 |
| Senior Member Join Date: Jun 2006 Location: Southern french alps, right by the Italian border
RG, the only thing which might be a problem is, reliability of the electronics. How long will they last slowing down and accelerating? Besides this, i'd like to see one showing up in euroland for that cheap |
| | #5 |
The motor is a brush-type universal motor, I think. At least it has brushes. The electronics is, frankly, the most trivial part of this. The mechanics of getting a motorized spindle set up for variable speed is the hard part - to me at least. I almost bought one to play with. Maybe I will go back and get one. ... like I need another project... |
| | #6 |
| Senior Member Join Date: Jun 2007
A variac would solve the speed problem but that would end the "cheap" winder part. It would be a nice compact unit. Two coils at once??
| | #7 |
I looked in the online manual for the thing at the HF web site and there is some kind of electronic speed control board inside the base. I think that one could work with that to get a lower controlled speed. Not sure, but probably.
| | #8 |
R.G. I can't seem to be able to find it on the HF site. Would you mind giving us a link? Thanks. Max. |
| | #9 |
| | #10 |
I did a search on "mini bench grinder" and found much the same thing at several ebay tool sellers, although at higher prices.
| | #11 |
Ive seen this same one for $90.00, and the attachment is another $35. I got mine locally for $27.00 with the attachment ????? Thats strange shit right there. Gotta shop good for your tools. Its a cool little grinder to have. Very small too.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Sewing Machine Coil Winder? | tbryanh | Tools and Coil Winding Gear | 53 | 11-20-2008 03:27 PM |
| crappy coil winder | Mystic | Pickup Makers | 8 | 02-16-2008 07:34 PM |
| Coil Winder? | tbryanh | Tools and Coil Winding Gear | 3 | 04-09-2007 01:56 PM |
| Coil winder plans part 1 | DoctorX | Pickup Makers | 5 | 01-18-2007 02:43 PM |
| coil winder plans part 2 | DoctorX | Pickup Makers | 0 | 01-18-2007 02:53 AM |
