| | #1 |
| Member Join Date: Jul 2007
| Thoughts on PRS 513's pickup system
I was really impressed by the sound and versatility of those 513. But it seems nothing strange, a single coil that becomes humbucker not in the paf way but in a more "bass-pickup-like" way. Am I wrong? I was tempted to experiment on that, then I discovered 513 and.. whoops, someone already did it. Let's discuss that thing. It's simple, why isn't it popular?
__________________ Biarnel Liuteria Italian handmade guitars and basses http://www.biarnel.com/liuteria/ http://www.myspace.com/biarnel |
| | #2 |
| Senior Member Join Date: Jan 2007 Location: Stockholm, Sweden, Europe, Terra Nostra
Dunno what you mean with bass pickup like. I watched a YouTube demo of that guitar and my first reaction was that the switch system was a standard 5-way, while the 3-way "only" switched the HBs from Coil-cut to parallel HB to Series HB. But I have never had the opportunity to examine one first hand so hopefully someone that has will give us their idea. |
| | #3 |
The main feature is that the HB is not an HB but two true single coil. So you have "strat" tone, and not the false single coil tone of a HB coil cut. (well, to me, HB in coil cut is good enough, anyway!) I think I heard, in that youtube video you mentioned, "the good thing is that in position 1 and 5 we have single coil BUT it's hum canceling!". uhm... maybe I misunderstood! I dont understand why the middle single coil is there. The middle is used RW/RP in a strat S/S/S setup, in pos. 2 and 4, for hum canceling.. why use it in the 513, where you can do hum canceling with the coil next to the one you're using?
| | #4 |
| Paf style: a bar magnet underneath the coils, slugs or screws in the coil touching the mag. "bass" style (I mean, what you find usually in a bass humbucker): two coils, each one with individual mags.
| | #5 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
The pickups are tapped, so in single coil mode, you get the full coil, and in tapped mode, you get the lower output in series with another coil wound the same. Here's the patent applications: The system: 20050150364 The bobbin and pickup: 20050150365
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #6 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
there's usually nothing new under the sun, Velvet Hammer did a bucker with two single coil type bobbins a long time ago, uses pole screws but tall bobbins like a strat....
| | #7 | |
| Senior Member Join Date: Jun 2006
| Quote:
| | #8 |
There's a couple of schematics and lots of info here, http://www.gearbuilder.de/forum/m-1166136844/, ..but it's german and I really can't understand
| | #9 | |
| Member Join Date: Oct 2006 Location: Brisbane, Australia
| Quote:
Just stick it through one of the online translators. You get some pretty funky results but it's a lot more understandable than German The PRS 513 fastened a few the flair of the special because here a special control is used, how the manufacturer knows to report on its web page. What sticks in the end behind it, looks at throws quickly clear, if one once one the belong with it patent from the year 2005. Read about here the US-patent 20050150364 to that 513 of PRS and Co. to that. For the "going bad" now the Quintessens: Reason draft The PRS 513 is a HSH-guitar with a control technical peculiarity. Both doppelspuligen cartridge consist of two spools, that have respectively an Anzapfung in 55 to 80% of the turns. Over a so-called fashion-Switch, now three positions can be activated: 1. Serial Humbucker (100%) 2. of serial Humbucker with tapped spools (55% - 80%) 3. Single-Coil (a spool 100%) We look at once the consequences resulting electric from that: 1St Induction Because the amount of the turns goes in quadratic into the calculation of the Induktivität, different Induktivitäten can be produced in this manner: 1St L (therefore the full value, over that once again nothing well known is) 2. 0,3*L until 0,64*L 3. 0,5*L 2Nd capacity Because the capacity of a Humbuckers of many factors is dependent, only coarse estimations can be encountered there: 1St C 2. 0,5*C until 0,8*C 3. 2*C 3Rd resonance frequency Under the acceptance that the capacity of the cartridge is small against the cable capacity (what in the normal case so counts), yield self-following relative resonances: 1st F0 2. 1,8*f0 until 1,25*f0 3. 1,41*f0 4Th exit tension Here the winding number goes in proportionally into the size of the induction tension. Therefore: 1St U0 2. 0,55*U0 until 0,8*U0 3. 0,5*U0 5. It does not hum (almost) The Single-Coil-business so is displayed that a together control with the Middle-PU is again a Humbucker-fashion. The magnetic polarity of the 5 spool is follows how: Tease: A: north (Single-Coil) B: south Middle: C: south Bridge: D: south E: north (Single-Coil) the magic number is 6th 13 The PU-Selector functions like in many HSH-guitars. Therefore 1. 2. Tease tease|| Middle 3. Middle 4. Middle||Bridge 5. Bridge Altogether one receives so 13 different combinations of which 11 Humbucker-variants are. 7Th control One of control variants represented two in the patent the following picture shows:
__________________ www.geocities.com/philmailloux | |
| | #10 |
And the version I suggested would be a much simpler aproximation of that... OK, feel free to bang away on that statement now |
| | #11 |
Instead of translating that German text, why not just read the patent?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Ibanez Sonic Distortion..mods and thoughts? | jnee8871 | Guitar Effects | 7 | 02-27-2010 02:49 PM |
| Late night crazy thoughts- Ferrite poles | Sweetfinger | Pickup Makers | 1 | 05-05-2007 04:24 PM |
| What reed system do YOU use? | Phil m | Pickup Makers | 8 | 10-20-2006 04:26 AM |
| Any thoughts on a UL Twin? | dave////irongater | Theory & Design | 7 | 08-28-2006 04:32 AM |
| back plate shielding system | scorpio | Pickup Makers | 1 | 08-18-2006 04:16 AM |
