That may be on his private links for customers only. Tell you what I did, though. I took his diagram (I did buy his kit), blew it up on a copier to about 3 sheets. I had bought an 8 color set of cloth covered vintage wire (Radio Daze - great stuff), assigned some of Bruce's colors and some others I came up with, and then labeled the entire blown up diagram. As I wired up the kit, I highlighted each connection on the diagram. It's about as failsafe as you can get - the amp fired up first time (following Bruce's start up procedure). Pics will follow in the near future.
n5oet3h
LinkBack URL
About LinkBacks
