Old 08-29-2007, 11:14 PM   #1
tone control not working
I just put fender noiseless pickups in my 5string jbass. I followed the basic schematic but found that my tone control does not work. I have double checked my work and confident that I did it to specs. I am puzzled. Does anyone have any suggestions. Thankyou
leftside is offline   Reply With Quote
Old 08-29-2007, 11:32 PM   #2
Either the tone control is not connected to the signal or not connected to ground.
... or the cap and/or pot values are waaaay off.
Instructions sometimes assume expertise and leave stuff out, or are just plain wrong. If you can scan and post, or at least post the text, maybe the issue will become apparent.
Hope this helps!
ps - you did _solder_ the connections, right? twist-splices and wirenuts are not likely to be adequate.
Don Moose is offline   Reply With Quote
Old 08-30-2007, 12:32 AM   #3
Thanks for the quick reply.
For some reason I could not create an att on this computer (sorry), so I just wrote it out since it is pretty straight forward
---grounding
Since the pots on my bass is attacked to wood and not a metal plate I had to connect each pot to insure proper ground. first step terminal3 connected to each body of the npu and bpu. Terminal 3 of firts pot to terninal 3 of second pot and connected to body of third pot (tone) . thirdpot to bridge
---hotwiring
Hot wire (yellow) from neck-pu to terminal2 of first pot. Ground (black) to body of first pot. Hot from pot1 terminal1 to [pot 2 terminal1]
Hot wire (white) from bridge-pu to term2 of second pot. Ground (black) to body of second pot. Hot from pot2 terminal1 to [pot 3 (tone) terminal two]
---tone wiring
this part I tried several different ways.
one way was to...
Cap connected term1 to body. Term 3 empty
Anotherway way...
Hot connected to pot 3 terminal ONE. Cap connected term two to body. Term 3 empty
jack...
Hot terminal from pot three and then ground to pot three body.
Old 08-30-2007, 12:59 AM   #4
OK - the usual way for these things is:
- PU1.hot to POT1.1 (terminal located at full clockwise (CW) rotation)
- PU2.hot to POT2.1 (terminal located at full clockwise (CW) rotation)
- POT1.2 (wiper) to POT2.2 (wiper) to to POT3.1 (terminal located at full clockwise (CW) rotation)
- CAP.1 to POT3.2 (wiper)
- CAP.2 to POT3.3 and POT3.body
- PU1.gnd to POT1.3 and POT1.body
- PU2.gnd to POT2.3 and POT2.body
- POT1.3/body to POT2.3/body to POT3.3/body to JACK.sleeve(gnd)
You GOTTA connect POT3.3 to _something_ grounded, or the pot's just floating and the tone control won't control anything.
Unless I misunderstood something you said - if so, please try again.
Hope this helps!
Old 09-04-2007, 03:37 PM   #5
broken tone pot fixed
It turned out that it was the paint in the cavity against the pots creating an extra ground and dispersing the signal. Paint... who knew!? A little electrical tape between the body and the pots took care of the problem! It was one of those stupid problems that I was lucky someone had experience with. Anyway, Thanks for your help.
Old 09-05-2007, 12:45 AM   #6
Mars Amp Repair's Avatar
yeah,
that is conductive paint designed to sheild the pots & connections from external noise. glen
Mars Amp Repair is offline   Reply With Quote
100k A for tone control walkman Theory & Design 3 08-03-2007 05:54 AM
tone control formulas Amagic Music Electronics 1 07-22-2007 09:34 AM
How to add tone control to my VOM Champ? Regis Mods & Tweeks 5 06-02-2007 08:42 PM
Tele tone control cap question Regis Guitar Tech 3 04-17-2007 08:56 PM
Tubescreamer-type tone control Matt T. Guitar Effects 6 11-17-2006 09:41 PM
