| | #1 |
| Member Join Date: Jan 2007
| MXR Phase 90
Is it possible to modify the mxr phase 90 not to sweep, just use it as a booster pedal? Or madify it to where it sweeps much slower and lower? Thanks |
| | #2 |
To the first question, no. To the second question, yes. The range of where the notches are is given partly by the .05(.047uf) caps in each of the 4 phase shift stages. If you wanted the pedal to have its lowest sweep point even lower than it currently is, you will want to increase that capacitance. You could do this by replacing those 4 caps with .068uf caps, or perhaps soldering a .01uf cap in parallel with the existing ones on the copper side of the board. The speed is partly given by an electrolytic capacitor in the LFO subcircuit. It is supposed to be 15uf. If you increase it to 22uf, you will likely be able to achieve slower sweep rates, although at the cost of fastest sweep rates. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Maestro PS-1 Phase Shifter Questions | JeffersonRhodes | Guitar Effects | 6 | 01-15-2010 05:49 PM |
| Phase 90 mods | tuberattler | Guitar Effects | 20 | 12-15-2008 06:11 AM |
| 'Scoping the phase inverter | Matt T. | Maintenance, Troubleshooting & Repair | 7 | 03-04-2007 03:05 PM |
| CF-driven phase inverter? | AdmiralB | Theory & Design | 14 | 01-08-2007 01:36 AM |
| Phase Inverter and Reverb Phase | Daver | Theory & Design | 5 | 08-21-2006 04:25 AM |
