| | #1 |
| Acoustic model 125, schem needed please
Here I am, asking for a schem, again. Sorry. Where can I obtain a schematic for this amp? Thank you. JC |
| | #2 |
| Junior Member Join Date: Jul 2006
Is that a Fender?
| | #3 |
No, it's an Acoustic. What part are you servicing? WHich power amp card is in it, 170074 or 170080? Are the preamp and EQ cards 170078 and 170076 respectively? |
| | #4 | |
| Quote:
I don't know yet. It had a cold and broken solder joint where the power transistor's card meets the rest on the power card, and a loose cable in the preamp card, but the amp still doesn´t work. The amp powers up and there's little hum coming out from the speaker, that's all for the moment. serial number: 12501554 Power amp card: 170080 Preamp card: 170078A EQ card: 170076A JC | |
| | #5 |
It's in the power amp or around it I belive. I get a good signal in the headphones that responds to the EQ pots, from the preamp out jack. There is very little sound coming out from the speaker when I plug the signal generator in the power amp input jack, but only when the generator output level is sent to it's maximum level. |
| | #6 |
The fault is in the power amp board. I have a transistor that is gone, a 40409 RCA, so I will replace it's companion too, the 40410. I'm guessing these are the drivers, but a schem would help for sure. There is a little component placed between these two transistors that looks like a diode, with a white case and no marks, that I don't know what it is or what it does in the circuit. I've been searching for a schem with no luck. Maybe someone from you have serviced one of these amps and remember what part of the amp I'm talking about. I'm trying to avoid changing all the transistors in the board. One of the power transistor's collector from one side had a broken solder point and the 40409 belongs to that side of the power amp section. |
| | #7 |
It's fixed. I just wonder if a cold solder joint in a power transistor's collector may blow it's driver. żIs this possible? |
| | #8 |
Depends. If the output rail tries to draw all its current through the base of the output device, which the driver tries to provide. Do you no longer need drawings? Send an email to tmenzo at msn dot com if you do, and I will scan it in. |
| | #9 |
No, it's ok Enzo, truly. Thank you very much. |
| | #10 |
| Junior Member Join Date: Sep 2007
| Acoustic 125 Pre Amp
Greetings, I have a guitar in need of pre amp ... please advise Thanks, Bruce 480-516-2455 bew1@cox.net bwashbur@insight.com Last edited by eddybruce; 03-04-2008 at 11:51 PM. Reason: adding email /phone |
| | #11 |
| Senior Member Join Date: Jul 2007 Location: Indianapolis
e-b, I think you need to start a new thread on this topic - maybe in one of the guitar tech forums. Here, at the end of a non-related thread, it's not likely to get much useful attention. Hope this helps! |
| | #12 |
| Member Join Date: Aug 2007
| www.acousticcontrolcorporation.com |
| | #13 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Becoming worthless Quote: How about just sharing some info like the rest of us. Otherwise your just another annoying free commercial here and that is not in the true spirit of AMPAGE. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| silvertone 1434 photos needed | lexluthier72 | Vintage Amps | 2 | 02-28-2008 03:35 AM |
| Acoustic transparency - grill material | casey73 | Cabinetry | 16 | 08-05-2006 12:35 AM |
| any one in the uk, 5e3 parts needed. | 31trum | Build Your Amp | 0 | 07-09-2006 01:55 PM |
| DOD - Punkifier Schematic help needed | orson | Guitar Effects | 3 | 05-26-2006 06:38 PM |
