I've tried just using a filament transformer in reverse. I needed about 60Vac so I tried using a 12.6V 4W transformer supplied from the 6.3V filament supply. I don't recall the numbers but I didn't get as much voltage out of the thing as I thought I would. I attribute my problems to the following:
Small transformers have poor voltage regulation. Designers take this into account when they design the parts. So, a 12.6V transformer might actually have a 14 or 15V winding that loads down to 12.6V at the spec'd max current. This eats your lunch and sticks you with the tab when you try to run them in reverse.
I suggest you use a 6.3V 1amp transformer and a full wave bridge on the output side to make your DC. There is a temptation to just raise the impedance in the bias adjust circuit, like using 100K pots, but this could lead to other problems depending on the tubes used.
LinkBack URL
About LinkBacks
