| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: Jun 2006
| Trace Elliot C100 Speed Twin
I just picked up a mint condition Trace Elliot C100 Speed Twin. It did not come with any footswitches. There is an 8 pin DIN jack for a 5 function footswitch. I cannot find any info on the original footswitch that Trace Elliot sold but did get a schematic of the amp and see that I can build one with momentary switches. I would like to be able to have LED's on this homemade footswitch to be able to see what condition the switched functions are in. Does anyone have a schematic of the original footswitch? |
| | #2 | |
| Senior Member Join Date: Sep 2006 Location: Englewood, CO
Say, I noticed that on the Britishaudioservice.com site, there are free owners manuals downloads. They have the pin-out for the Speed Twin in there. glen - mars amp repair Quote:
| | #3 |
Thanks. I was able to find out more about the original (unavailable) footswitch. It seems that the original footswitch had a duplicate digital switching circuit that is in the amp itself. This is how it was able to have indicating LED's for the switch functions. I have since talked to a tech at the US service center for Trace Elliot and he said without this circuitry it's impossible to get remote indication. The best I can do is to build a footswitch with the appropriate momentary switches, multiconductor cable and DIN plug (which I found at Mouser) and not have indicating LED's. It's worth it since this amp sounds really good and I will be able to remotely control Channel Selection, Boost, Master Selection (this amp has 2 switchable master volume controls) and the Effects Loop. |
| | #4 | |
| Junior Member Join Date: Oct 2007
| Results?? Quote:
John | |
| | #5 |
Thanks for following-up. I did build the footswtich without any indicating LED's. It works well and my son, the actual user of the amp, is very happy with it. |
| | #6 |
| Gibson Super Goldtone
Thought I'd post a few pics of my Super Goldtone, 30 watts Class A, 1x10" and 1x12". Currently using a 2 button footswitch, but wish I had the 5 button (non-latching) footswitch under discussion here. ![]() ![]() ![]() ![]() ![]() Last edited by johnnieboy2; 10-30-2007 at 09:49 PM. |
| | #7 |
Sorry I didn’t get back to you sooner. As I mentioned before, my son has the amp at school. He finally brought the footswitch home yesterday so that I could take pictures. See the attached JPEGs. It’s pretty simple: Refer to the attached “Switching Circuitry” document. This has excerpts from the Schematic manual and describes how the switching works and gives a printout of the pins on the mini-din jack. The Trace Elliot amp supports two footswitches as shown on the diagram. Just reference one of them. You basically short the appropriate pin to the ground pin , 0V, with a momentary switch to activate that function. I bought the 8 pin mini-din plug from Fry’s. You can also order it from Mouser I believe. I also bought the momentary switches from Fry’s. You can see from the picture of the inside of the footswitch that I am just using one switch per function then shorting the appropriate line to a common that is wired to the 0V pin as per the diagram. I used heavy duty heat shrink tubing to reinforce the strain relief for the mini din plug since I saw this as a potential weak link. For reference, attached is the manual and schematic for the Trace amp. Post Construction Notes: My son asked me to include his comments on the construction… The switches are a little too close together (he has size 15 feet!) The box is a little too tall. Once I find a more suitable enclosure, I’ll probably rebuild it. Hope this all helps; let me know how it works out for you. Harold Speed Twin II C100 & H100.pdf SPTW.pdf Switching Circuitry.doc Footswitch Inside.jpg Footswitch Top.jpg |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Any thoughts on a UL Twin? | dave////irongater | Theory & Design | 7 | 08-28-2006 04:32 AM |
| Super Twin distortion? | drewl | Maintenance, Troubleshooting & Repair | 3 | 07-11-2006 03:22 AM |
| Safety warning: Sharpie Twin Tip markers can be lethal! | Steve A. | Lobby | 1 | 06-20-2006 11:20 PM |
| Slight problem with my Fender Twin Reverb. | Humbucker | Vintage Amps | 2 | 06-13-2006 02:03 AM |
