Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 09-20-2007, 08:59 AM   #1
Alnico Blue..Safe in my Vintage 5E3
Excuse my ignorance but will fitting the Blue harm my 1959 5E3.
It will be here today, I read in a thread about fitting a Attentuater
Don't want any more expense..
Thanks
Gibby
Gibby is offline   Reply With Quote
Old 09-20-2007, 10:05 PM   #2
bob p's Avatar
this questions comes up a lot. instead of having us retype the answers, could you try using the search function? lemme know if that doesn't work for you and i'll provide a link to the existing thread.
__________________
"I know nothing."
- Schultz, Hogan's Heroes
bob p is offline   Reply With Quote
Old 09-20-2007, 10:11 PM   #3
bob p's Avatar
here are the terms to type into google to perform a site-specific search that hits all of the relevant threads. if you like, just do a simple cut and paste of the words below into the google search box.
Code:
blue 5e3 site:http://music-electronics-forum.com
have fun.
__________________
"I know nothing."
Old 09-28-2007, 07:03 PM   #4
Thanks
Gibby
the blue will be fine in your 5E3 and it'll sounds stellar!
nokaster is offline   Reply With Quote
Old 09-28-2007, 07:11 PM   #5
Alnico Blue in 59 5E3
Sure it sounds great but not in the same way !
I can't get that over driven Neil tone with out being ridiculously loud and even
the it's to spikey for my ear's.
My P12R should be back repaired soon, ok it won't be a loose as it was
but I'm sure it will be more or less what I'm after.
Thanks
Gibby
Old 09-28-2007, 07:45 PM   #6
TD_Madden's Avatar
you are running 6L6s in your Deluxe..right?
TD_Madden is offline   Reply With Quote
Old 09-28-2007, 08:04 PM   #7
Tubes
All they say is M/P Made in China !
I have the 5Y3 in there, my Fender Hot Rod Deluxe has Two whacking big Tubes, 6L6. Should I be running these in my 59 ..
The label in the cab says, 5Y32 GT, 6V6GT, 6V6GT, 12AX7, 12AY7
Make any sense ?
Thanks
Gibby
Old 09-28-2007, 09:19 PM   #8
TD_Madden's Avatar
Neil uses 6L6s in his '59 5E3. Other mods are necessary if you want to run these safely (such as replacing the cathode reistor with a 10-watt unit)....I'm guessing that will kick the power up to perhaps 18 watts, the main difference is a little more headroom. The reconed P12R MAY be ok using those....
Old 09-28-2007, 10:33 PM   #9
6V6's
Thanks for the advise it is very much appreciated.
I have checked and my Tube's, they are 6V6's....
I don't require any more head room with the Celestion in there, but when the
P12R return's more head room could be welcomed.
What speaker does Neil use, I like the idea of 6L6's but will cry if I blow the
Jenson again
I have a C12Q here which sounds nearer the P12R than the Alnico Blue !
Huge thanks for all your imput
Paul
Old 09-29-2007, 01:01 AM   #10
TD_Madden's Avatar
March '92 issue of Guitar Player has an excellent interview with Larry Cragg, Neil's amp-tech since '76. Although there is a TON of information on Neil's rig, he doesn't specifically mention the speaker. Since they were available with both the P12R AND the P12Q, I'm betting it's the Q model...just more likely to handle the power.
If you like, I'll try to scan-in the two-page interview and send it to you.
Old 09-30-2007, 10:55 PM   #11
fyl
fyl's Avatar
Neil Young uses vintage Jensen C12N's, reconed using ribbed cones from A Brown Soun.
"We first heard about Larry [Cragg] from John Harrison at A Brown Soun in San Rafael, California. John had told us that he kept a “special stash” of vintage, ribbed Jensen cones that he used to recone the C12N speaker in Neil’s famous narrow panel tweed Deluxe. According to John, an overnite package would occasionally appear shipped from somewhere on tour, and John would recone the Jensen and ship it back to Cragg the next day."
From the Tonequest Report Volume 7 Issue 11, September 2006
http://www.tonequest.com/pdf_pubs/sa...ep06_Proof.pdf
fyl is offline   Reply With Quote
Old 10-01-2007, 03:35 AM   #12
TD_Madden's Avatar
attached '92 Guitar player interview...download and zoom to read.
Old 01-27-2008, 02:56 PM   #13
I had a Celestion Alnico Blue in my 5e3....I blew the cone one night playing classic rock with my 5e3 cranked! Ouch that hurt. they aint cheap. Now I use a ceramic Hempcone Tone Tubby...I love it!
BobbyB is offline   Reply With Quote
Old 01-27-2008, 03:29 PM   #14
5e3 Speaker
I just record with with my Deluxe or practice.
I need a speaker that will break up nice and early like the original.
I had it re conned but it's not the same (((
Gibby
Old 02-04-2008, 03:22 AM   #15
I never heard the Alnico Blue producing such smooth distorted tone as when 5w amp is used on it, otherwise it's been a favorite speaker.
15w amps when pressed into 1 x 15w speaker seem to distort or make the speaker cry a bit by the time it's into heavier tube/output distortion, for that I prefer 2 speakers and have greenbacks in 2 x 12'' cab. which is much too loud for bedroom, about right for gigs.
petemoore is offline   Reply With Quote
15w Alnico Blue [safe w/15w ?] petemoore 5 E 3 9 03-02-2008 05:18 PM
Installing a Bigsby vibrato arm myself. Safe? Smart? Wiborg Guitar Tech 3 09-18-2007 02:33 AM
How to grade vintage Alnico humbucker magnets. JGundry Pickup Makers 11 08-19-2007 12:59 AM
When is it safe to work on? ajs Maintenance, Troubleshooting & Repair 1 07-16-2007 01:27 AM
Differences between Alnico 2 and Demagnetized Alnico 5 OFM Pickup Makers 20 04-20-2007 02:25 AM
