Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By TigerAmps
  • 3 Post By Jazz P Bass
  • 1 Post By Justin Thomas
Thread: late 70's UL super reverb speaker impedance
    Apr 2008
    Croatia
    52
    Does anyone have this amp? I'd like to know the individual speaker impedance for this amp, schematic says 16 Ohms: http://schematicheaven.net/fenderamp...-bmstr_rev.pdf
    But I have four 8 Ohm speakers (they look stock, blue fender label, CTS I guess) in my amp, paralleled total load measured is 2.3 Ohms.
    The back of the amp says 4 Ohm minimum load. My best guess is that the previous owner replaced the speakers with incorrect impedance. Or Fender screwed up...
    Feb 2015
    116
    So it looks like it should be a 4 ohm load the amp is expecting so the speakers should be 16 ohms each.
    Do the speakers have an ohm spec on them? Do they say 8 ohms or are you assuming?
    I would start by un-soldering all 4 speakers and measuring them individually at the speaker with no wiring attached. They all measure about the same.
    If they were 8 ohms, the reading should be less then 2 ohms (like 1.x).
    2.3 does seem on the low side; what type of meter are you using? is it set to the lowest setting for ohms?
    pdf64 likes this.
    Dec 2008
    Wernersville, PA
    12,143
    Yeah, the schematic shows (4) 16 ohms in parallel for a total of 4 ohms.
    I wouldn't put the blame on Fender.
    Aside: the output transformers used back then are pretty tolerant of slight mismatches.
    2.3 compared to 4?
    Meh.
    Supporting Member
    Staffordshire UK
    3,318
    Well, the speaker resistance should be a bit lower than the nominal impedance; but then most meters will read high on such low resistances. So best to do as per post #2.
    The VHT on these amps is rather high, so if it's going to be pushed hard, to give the tubes a fighting chance it may be a good idea to ensure that the intended load is connected.
    Chill-Ville, VA
    2,624
    I think the extra .3 or so ohms can probably be accounted for with meter lead resistance, along with that mile of speaker wire back there. I'm with Jazz on this one, especially if that OT is original. Because even if they WERE all 16 running in parallel, add an extension cab, bang, 2 ohms.
    My Bassman has run for many years with the wrong load, and not quietly, either. And the only tube death came when the bias caps dried out & failed.
    Justin
    Jazz P Bass likes this.
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  1. Reverb mods for '70's Super Reverb
    By Steve A. in forum Mods & Tweaks
    Last Post: 01-10-2018, 01:13 AM
  2. Replies: 4
    Last Post: 09-04-2014, 01:21 AM
  3. Replies: 6
    Last Post: 10-31-2010, 09:28 PM
  4. 70's Super Reverb problems
    By andymef in forum Music Electronics
    Last Post: 12-31-2008, 03:36 PM
  5. Reverb mods for '70's Super Reverb
    By Steve A. in forum Guitar Amps
    Last Post: 07-20-2006, 06:56 AM
