Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 09-27-2007, 03:25 PM   #1
Low output Fender Bandmaster
I'm planning on building an amp with the following characteristics :
- Fender style
- tremolo circuit from the Bandmaster 6G7-A
- spring reverb
- single 6V6 output
- single 10" speaker
What I have in mind is to take the 6G7-A schematic as a starting
point and replace the PI and output section with a Champ output.
Then add a typical Fender reverb circuit.
I'd like to use Allen Amps TP40D (320V-0-320V @ 180ma,
5V @ 3A, 6.3V @ 4.5A) power transformer along with the
TO11C output transformer.
Is there any problem with this idea ? Suggestions would be welcome.
Thanks,
Paul P
Paul P is offline   Reply With Quote
Old 09-27-2007, 04:44 PM   #2
seems good, i assume the hefty PT is so that it can handle the reverb? i dont know much at all about reverbs, but do they suck that much power?
black_labb is offline   Reply With Quote
Old 09-27-2007, 04:56 PM   #3
I doubt reverb circuits use alot of current. Look how small the power tranny's are in Princeton reverbs or even Deluxe reverbs.
sounds like a good idea for a build, but that's pretty much the way Fenders are anyway....basically the same preamp circuit with many different output combinations. 2-6V6's, 2-6L6's or 4-6L6's!
drewl is offline   Reply With Quote
Old 09-27-2007, 05:30 PM   #4
Are you planning to use a tube rectifier???
Chuck
Chuck H is offline   Reply With Quote
Old 09-27-2007, 08:24 PM   #5
Thanks for the replies.
The main reason to use such a large transformer is just to
have it in reserve if I later decide to go to a move powerful
output stage.
I'll be building my circuits as modules so that I can experiment
with swapping different parts in and out. I'm particularly
interested in trying out different tremolo circuits.
I plan on using a tube rectifier (probably a GZ34).
Paul P
Old 09-27-2007, 09:09 PM   #6
nice, how about another single ended output tube that you can switch in/out for more power?
Old 09-27-2007, 09:48 PM   #7
Adding another output tube shouldn't be a problem but I'm not
sure how to wire it. Do you just use a "Y" to the grids and
another one from the plates to the output transformer ?
Paul P
Old 09-28-2007, 09:53 PM   #8
I believe you can wire both tubes in parallel, and just have a switch between the cathode of one output tube and ground, thus turning off the one tube.
Good Fender Twin Output Tranny Replacements? fatboy01 Mods & Tweeks 14 09-19-2007 08:11 PM
bandmaster 100 watts rockingrandy Theory & Design 2 09-01-2007 10:12 AM
69 Fender Bandmaster reverb ohms output benindavis Vintage Amps 2 08-17-2007 09:50 AM
69 Fender Bandmaster Reverb ohm switch? benindavis Vintage Amps 8 08-17-2007 09:50 AM
BF bandmaster measurements??? Satamax Cabinetry 0 01-30-2007 06:09 PM
