Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 09-27-2007, 10:58 PM   #1
Mesa Boogie Subway Rocket pots
Hi!
I want to replace the Master and Gain pots on said amp as they became noisy when turning them. I looked in many different places but nobody seems to offer the right ones. It is mainly about their size. They need to be about 1/2" to 9/16" in diameter preferably with a 1/4" flatted shaft. Can anybody recommend a source for them? Thanx.
bitcat is offline   Reply With Quote
Old 09-28-2007, 12:26 AM   #2
Pots in guitar amps are almost always made to order for the OEM. Mesa would have the controls. You would not find them at Mouser or someplace like that.
Have you tried cleaning the existing pots?
Old 09-28-2007, 12:49 AM   #3
bob p's Avatar
IME Mesa support for end users is great. They may not be able to route your call to the right person in real-time, but somebody will call you back and that person will have the answers.
__________________
"I know nothing."
- Schultz, Hogan's Heroes
bob p is offline   Reply With Quote
Old 09-28-2007, 01:27 AM   #4
+1 on Mesa support. Pretty decent typically.
I'd try Caig Deoxit cleaner and lubricant on the pots first.
Barry
xFallen is offline   Reply With Quote
Old 09-28-2007, 05:38 AM   #5
Also make sure the pots are not getting sprung. On a lot of recent era Mesas, if you swat the knob so it pushes inwards, it can actually push the back off the pot. SOmetimes it just gets loose.
IN those cases, demount the pot, and with large pliers, squeeze the little tabs tight again. The little tabs that hold the back cover on the pot. When it is loose, the wiper does not make as good contact with the resistive element.
Old 09-28-2007, 03:18 PM   #6
Thanx for all the replies. I will try cleaning them first. Aaaaa... do I have to open them for that? Or just spray them or something? Mechanically they look sound. If that fails I will try to contact them.
Old 09-28-2007, 04:50 PM   #7
This goes throgh the typical questions. I use the Caig cleaner then follow up with the protectant.
http://www.thegearpage.net/board/arc...p/t-13956.html
Barry
Old 09-28-2007, 05:29 PM   #8
bob p's Avatar
helpful link. see Dexter Sinister's post about different cleaning chemicals.
I'm not too embarrassed to admit that I've used WD-40.
__________________
"I know nothing."
Old 09-28-2007, 05:45 PM   #9
Well, nobody is born with this innate knowledge so...what do you do.
I haven't used WD-40, and not because I knew better so call it luck, but certainly lots of contact cleaner over the years. I think the contact cleaner is probably just as bad of an idea. I also used to quickly move pots back and forth to clean them out when they got scratchy. Oops.
Old 09-28-2007, 10:23 PM   #10
I had a some recent model boogie on my bench not long ago. Forget the exact
one.
Just about every pot on the thing was scratchy. That was a real head scratcher. Some how (maybe it was from here), I found out that Mesa put
some bad pots in some of their amps.
I called mesa and they sent me a replacement set. I think there was a nominal
charge.
They are great guys to deal with. Always courteous and prompt.
jcollins is offline   Reply With Quote
Old 09-29-2007, 02:38 AM   #11
Second that (or third rather) on Mesa support. about 5 years ago I was having a problem with my Subway. I called them up for a schem and they asked me if it was the one with the potted FX loop board. It was. They had me send the chassis to them and they replaced the entire board with a new one with fresh componants (including new filters , the amp was about 9 years old at the time). All I paid was shipping, even though I was well past the warranty date. They even asked me if I wanted a "bright" switch or a "fat" switch installed with the new board. Top notch service.
Of course the entire amp is now modified into something else. As it turns out, I just didn't like the amp the way it was anyway .
Never had a problem with the pots on mine, but Mesa will almost certainly help you if you call them.
Chuck
Chuck H is offline   Reply With Quote
Old 09-29-2007, 03:10 AM   #12
Cleaning pots.
Look at the pot where the three legs come out. Ther should be a space around them. Squirt cleaner in there.
bias mod for the mesa boogie subway rocket JC@ Mods & Tweeks 6 11-12-2009 06:22 PM
Mesa Boogie F50 Spence Mods & Tweeks 2 02-21-2009 10:49 PM
Mesa boogie 50/50 brewu22 Maintenance, Troubleshooting & Repair 20 11-13-2008 07:34 AM
Mesa subway rocket power section Justin Theory & Design 4 05-04-2007 03:18 AM
Mesa Boogie 2:one hundred mentale Maintenance, Troubleshooting & Repair 0 10-02-2006 11:53 AM
