Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 09-30-2007, 02:41 PM   #1
J175 substitute
Hi,
I am building a 3 channel dual rec..but can't find the J175 P-channel transistors :s ..any good suggestions??
thanx
Thomas
thomasdj is offline   Reply With Quote
Old 09-30-2007, 05:01 PM   #2
I do not know where you are located and do not know where you looked. The first place I looked, Mouser, claim to have them in stock in all manner of packages and ratings. They do not appear to be particularly rare basedon cursory scans through a few other retail suppliers.
Google is also a very powerful tool and probably among the first places someone should try. I just did a search with the exact wording from your post and had many viable hits.
Barry
xFallen is offline   Reply With Quote
Old 10-02-2007, 01:40 AM   #3
Most little P-channel JFETs will work, try a J174. Be aware the pinout might be different with differnt type numbers.
Go to Mouser and type J175 into the search. Then specify TO92 case style in the advanced search. They show a couple brands in stock. 48 cents or 26 cents, your choice.
Allied has the Vishay in stock for 58 cents.
Digikey has a couple thousand in stock for 43 cents each.
Jameco has the Fairchilds at 19 cents, and the Vishays for 34 cents.
Substitute for VTL5C3? clintronics Music Electronics 3 09-14-2007 02:04 AM
