Results 1 to 14 of 14
Like Tree9Likes
  • 2 Post By Justin Thomas
  • 1 Post By Justin Thomas
  • 1 Post By fastfolkert
  • 1 Post By Tone Meister
  • 2 Post By Leo_Gnardo
  • 2 Post By nickb
Thread: JTM30 bias and other tubes?
    Sep 2015
    the Netherlands
    29
    I just acquired a JTM30 in, like it seems, the original condition. Unmodded and with original tubes. (5881)
    It works and sounds good to my ears. I have not yet done any measuring inside.
    However, I have two questions:
    1 – I may stick with the 5881’s (perhaps throw in a new pair), but what I read here is that the bias (-39.1V) is fairly “hot”. I might add another 4 to 8 V zener to set it a little cooler. What is the approximate current through that zener-stack? (I have some 400 mW zeners at hand)
    2 – I have a few NOS Philips EL34. Is it possible to put these in, and if yes, what do I need to do (set bias? Other?).
    When I decided what tubes I use I will most likely keep it that way, so I think I do not really need a bias-pot.
    TIA!
    Schematics: Marshall Schema's
    Chill-Ville, VA
    2,254
    I know that eventually you will be asked to measure the current through the tube eventually, so if you know how... and what aschematic shows and what is true may be quite different. The bias voltages are relatively meaningless without knowing the current, plate voltages, etc, so we'd just be guessing. And given the (in)consistency of current production tubes... Don't worry about what others say is too hot or too cold. If the amp works and sounds good (or better) AND doesn't self-destruct, it's fine.
    That said, I'm assuming those are Sovtek 5881WXTs in the amp. If you replace them with the exact same kind (Sovtek 5881WXT), there's a chance you'll never have to adjust the bias again. Those things are damn-near close to "the indestructible tube" as we ever got. Don't confuse them with
    NOS 5881s or the new Tung-Sol reissues or the 5881/6L6WXT. Check the innards of the tubes, and if they match, you're set.
    As far as EL34s go, I'd take every precaution I could before plugging THOSE in... which to me would be a bias pot AND making sure my power transformer won't burn up from too much heater current draw... also may require some rewiring of the tube socket, grid and screen resistor values, etc.
    Justin
    pdf64 and The Dude like this.
    "Are you practicing in the lobby of the municipal library? It's still a guitar amp and it SHOULD make some noise (!!!)" - Chuck H. -
    Chill-Ville, VA
    2,254
    Also: seems you have two identical threads in the same forum? Just grab one and stick with it. I recommend the other one, because Enzo is answering that one...
    Justin
    pdf64 likes this.
    Sep 2015
    the Netherlands
    29
    Justin
    I know, my mistake. Sorry. The mods can lock one of them.
    Sep 2015
    the Netherlands
    29
    Thx, specifically for the EL34 warning.
    My 5881's I have at home are indeed those "indestructable" Sovteks.
    Sep 2015
    the Netherlands
    29
    OK, I did some measurements in the JTM30, with "known good" Sovtek 5881:
    R between CT and A1, resp. A2: 76.9 and 78.2 Ohm
    V anode-cathode: 420 V
    V between CT and A1, resp. A2: 3.18 and 3.14 V
    Yielding:
    anode current resp. 41.4 and 40.2 mA
    bias power resp. 17.4 and 16.9 W
    Which is approx. 56% of Pmax (30W).
    Vbias at the zeners was -40,4 V
    The amp sounds great (IMHO) and does not cut out or so. Inside it looks like new and it is unmodded.
    The only thing is dat at very low volume (master at 1), there's a trace of distortion audible. Kind of cross-over-like sound.
    At higher volumes (bedroom-volume and up) it's not noticeable anymore.
    Perhaps this is normal for a JTM30? (which you do not buy for sparkling cleans anyway...)
  7. #7
    Sep 2015
    the Netherlands
    29
    Update: the "distortion" I heard was due to a speaker that made a mechanical sound. Not coil-rubbing in the magnet but something else, perhaps the wires.
    I replaced it with a matching Eminence Legend speaker and the amp sounds awesome to me; gigged with it already and worked flawlessly.
    I'm a happy camper ;-)
    The Dude likes this.
  8. #8
    Supporting Member Tone Meister's Avatar
    Aug 2012
    North Carolina, USA
    575
    I'm late to the party, but I can tell you from experience the power transformer in the JTM30 will not accommodate the increased heater current requirements of an EL34. We have used 6L6GC (conservatively biased with bias pot mod) successfully with two different JTM30s, and they both have been running for several years that way. But I think 6L6GC would be the absolute limit of that PT.
    I have searched in vain for a drop in upgraded PT for the JTM30 and never found one. At some point, there are only some many "upgrades" that make sense with an amp at this price point.
    fastfolkert likes this.
    Quote Originally Posted by km6xz View Post
    "I have come to the conclusion that the biggest risk to amp performance/reliability and "tone" is players reading the internet, not bad tube brands, and certainly not the often argued over capacitors."
  9. #9
    Sep 2015
    the Netherlands
    29
    Quote Originally Posted by Tone Meister View Post
    Thx. for the info. I did two rehearsals and one gig so far with the Sovtek 5881 biased at approx. 40 mA/17 W each. The tone is good for me, the idle dissipation is not too high and I plan to leave it that way.
    Maybe sometime in the future I'll mod the boost channel (a tad too fizzy for me).
  10. #10
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,475
    BYW, 5881 is rated at 23W, not 30W. I used a couple of Russian military biscuit base 6P3S. They are identical to the in construction to the aged 5881's I took out.
  11. #11
    Sep 2015
    the Netherlands
    29
    Quote Originally Posted by nickb View Post
    I have the 5881WGC, which I thought was 30W..??
  12. #12
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,451
    Quote Originally Posted by fastfolkert View Post
    A little history:
    5881 was the name applied starting late 1980's, by distributor New Sensor (Sovtek, Electroharmonix) to USSR made wafer-based beam power tubes that resembled 6L6's in an effort to get USA buyers to accept them. "Hey remember those fine (real, New Jersey made) TungSol 5881's from the 50's-60's? Huh? Well buy these because, uh, they're short. And you probably won't respond to 6P3S. So we're calling them Sovtek 5881, later we'll put on a long base and call 'em 5881WXT. How's that? Buy 'em!" Turns out the Russian imports were indeed fine tubes and could stand a lot of use and abuse, with real plate ratings far beyond 23 watts.
    To expand the confusion now there are JJ and (Russian) TungSol 5881's, smaller envelope versions of 6L6's. Chinese too, Ruby has 'em 6L6GCMS. If you like a good tube in a small glass bottle, I'm favoring the JJ 5881 lately, delivers excellent power & tone, no clanking bonking mooing microphonic noises, no premium price, just good stuff . What the real plate rating of any of these is, ?????
    DrGonz78 and fastfolkert like this.
  13. #13
    Dec 2009
    Devon, UK
    2,475
    It's 23W - see later. Now here's the twist. I thought I'd hop over to new sensor's web site a grab the datasheet but the site has gone!
    http://www.svetlana.com/ and http://newsensor.com/ - no DNS entry. Electro-Harmonix | EHX.com | Effect Pedals, Vacuum Tubes, Pro Audio is still up. Anyone know what's going on here?
    UPDATE:
    In the absence of a data sheet, the way to be sure is to measure the length of the plate. A 23W 5881 is 34mm the 6L6 is roughly 42mm. Here a piccie of a 6L6WXT, a 5881 WXT and a 6p3.
  14. #14
    Sep 2015
    the Netherlands
    29
    Thanks for the insight guys!
    In that case I'm biasing the 5881WGC's at 75% Pmax.
  1. Marshall JTM30 bias mod problem & IC3 (LM348) problem
    By Tone Meister in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-28-2016, 12:10 PM
  2. Jtm30 output tubes not lighting up?
    By the great waldo in forum Guitar Amps
    Last Post: 01-22-2015, 08:06 PM
  3. Replies: 59
    Last Post: 03-23-2013, 11:42 PM
  4. jtm30 bias mod problem
    By donegone in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-13-2009, 03:17 PM
  5. 2 Tubes fixed bias/2 tubes cathode bias
    By lowell in forum Guitar Amps
    Last Post: 11-30-2007, 08:25 PM
