Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Beef Coon
Thread: Cutting ALNICO Magnets
    May 2013
    Monterey Bay
    140
    I'm making some one-off Firebird pickups so trimming some magnets and cutting some steel plates.
    For the ALNICO I used a Dremel with a reinforced cutoff wheel. Below are a couple cell phone pics.
    I made a little wooden "cradle" to hold the Dremel on its side and clamped to my bandsaw. Made a cradle since the Dremel is more or less round and easiest way to get a nice firm clamp.
    I did it this way as it seemed it would be easier to control the work piece rather than the tool. YMMV. Haven't seen a ton of info or pics of how others do this so figured I'd share.
    Cutting was on the slower side as expected - great for prototyping ands one-offs though.
    Reasonably straight cut, will use disk sander to tidy-up.
    CheopisIV likes this.
    Senior Member jack briggs's Avatar
    Oct 2007
    Raleigh
    250
    hope you kept it flooded with cutting fluid or water?
    BTW - I've cut AlNiCo bar mags by just scoring with the Dremel and cutoff wheel, then breaking with pliers. the end can be cleaned up on a bench grinder with water quenching.
    cheers,
    May 2013
    Monterey Bay
    140
    Quote Originally Posted by jack briggs View Post
    cheers,
    I was going to score and break w/ pliers, but it was cutting so well, I just continued cutting. I cut the short length with a wet tile saw.
    Are you saying the physical properties of the magnet will change from the heat?
    Txs.
    Supporting Member
    PDX
    3,186
    You'd have to get the AlNiCo really hot to permanently affect it's magnetic capacity. Alnico are the most heat resistant magnets known to man.
    Oct 2007
    Raleigh
    250
    Quote Originally Posted by David King View Post
    true, you may not reach the Curie temp with a Dremel, but any grinding operation should be done with coolant.
    Boston, MA area
    2,578
    Don't try to cut alnico at high speed using diamond tooling - the diamond (which is carbon) will dissolve into the alnico, which is largely iron. If you see sparks, it's too fast.
    If you make the magnetic path too short, the magnitization will prove unstable, and the reduced magnet will lose its charge over time.
  7. #7
    May 2013
    Monterey Bay
    140
    Lots of good info being shared, lots about good general practices for cutting metal.
    I'll just reiterate that the method used in my original post worked very well for trimming down a couple full size ALNICO bar magnets - with no ill effect on the magnets, and no ill effects on the tool.
    One reinforced cutting wheel lasted long enough to cut down two magnets. Forgot to mention that this was done outside, as the dust is nasty & these magnets were not magnetized to keep debris out of the cutting path.
  1. charging alnico magnets with rare earth magnets?
    By guitar_slinger8 in forum Pickup Makers
    Last Post: 03-28-2012, 03:10 AM
  2. Cutting AlNiCo
    By cryptozoo in forum Pickup Makers
    Last Post: 03-17-2011, 07:49 PM
  3. Cutting Alnico Magnets?
    By ken in forum Pickup Makers
    Last Post: 03-25-2009, 06:03 AM
  4. Alnico 5 Magnets
    By Woodenspoke in forum Pickup Makers
    Last Post: 01-10-2008, 03:23 AM
  5. Cutting AlNiCo
    By Spence in forum Pickup Makers
    Last Post: 12-02-2007, 09:08 PM
