Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By g1
  • 1 Post By Enzo
  • 2 Post By Jazz P Bass
  • 2 Post By drewl
Thread: takamine acoustic electrics issue cp-132sc
    Sep 2012
    Poole UK
    566
    Morning
    I don't normally touch this sort of thing, But a local guitar shop that i do repairs for asked a favour as they brought it working then it failed
    This acoustic has low output. Not pickup or battery. Injected a signal and i can see it til it gets to i ic called 4062
    This unit has 3 ic all with different numbers on
    signal seems to get going into pin 1 and 2
    any assistance ??
    have a good day people
    Dec 2008
    Wernersville, PA
    11,911
    What you see are two different opamps.
    UPC4572
    ADA4062
    The pinouts are standard opamp configuration.
    Pin 1 output A
    Pin 2&3 Input A
    Pin 4 -V
    Pin 4&5 Input B
    Pin 7 Output B
    Pin 8 +V
    Sep 2012
    Poole UK
    566
    thanks jazz bass. I did look at the ada4062 but pin 1 and 2 are connected together via track ( can see in the picture ) and ive tested with dmm. when i checked the net for pin out on a ada4062 i noticed the 1-2 are input and output so this lead me to believe that it wasn't an ada4062.
    will check tomorrow again
    g1
    g1 is offline
    Feb 2010
    9,171
    An op-amp with input connected to output is a standard unity gain buffer:
    Attached Thumbnails Attached Thumbnails 230px-op-amp_unity-gain_buffer.svg.png
    blindboybenton likes this.
    Certified Dotard
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,906
    Op amps have two inputs, an inverting one and a non-inverting one. It is very common for one input to tie to the output.
    Edit: g1 beat me to it.
    Sep 2012
    Poole UK
    566
    Many thanks
    Ive learnt something new today
  7. #7
    Dec 2008
    Wernersville, PA
    11,911
    Here are three circuits that I pulled off of the ADA4062 datasheet.
    Attached Files Attached Files
    TomCarlos and g1 like this.
  8. #8
    Jun 2006
    Norristown state hospital
    1,787
    here's a couple links with info on the Accuracoustic preamp with schems.
    I don't know why they used these crappy electrolytics for signal coupling except for space as they tend to fail, like the one I'm working on.
    https://www.musiker-board.de/threads...esucht.399060/
    Yustech GT-Guitars and Basses Solution.: Takamine AccurAcoustic Preamp Issues Part II
    Jazz P Bass and g1 like this.
  9. #9
    Supporting Member
    Dec 2009
    UK
    2,974
    I've fixed plenty Takemine preamps due to leaking electrolytics. The problem is not tied down to one particular version, either. Often they're so bad the tracks have corroded away. Even more difficult is those that are positioned between sliders and difficult to reach. I've been replacing the low-value electrolytics with Tantalum for the past 5 years and they're holding up fine.
  1. takamine acoustic electrics issue cp-132sc
    By blindboybenton in forum Guitar Tech
    Last Post: 01-09-2017, 01:58 PM
  2. Wal pro bass electrics
    By debass in forum Guitar Tech
    Last Post: 06-18-2011, 09:21 AM
  3. Takamine preamp, unity gain?
    By g1 in forum Music Electronics
    Last Post: 04-21-2010, 01:41 AM
  4. new CP audio pots <$1?
    By tedmich in forum Theory & Design
    Last Post: 08-10-2009, 03:32 AM
  5. Acoustic 470 reverb issue
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-27-2007, 04:54 AM
