Results 1 to 9 of 9
Like Tree7Likes
  • 2 Post By robrob
  • 1 Post By Chuck H
  • 3 Post By Justin Thomas
  • 1 Post By robrob
Thread: How do I mod my custom vibrolux reverb to reduce the harsh treble sound ?
    Jan 2017
    1
    Are there any tips out there to help me get rid of the way too trebly sound of this amp. I'm think that the 15 inch speaker would help but I'd like to try something else first that doesn't require major surgery
    Supporting Member
    Staffordshire UK
    3,321
    It's treble control has a wider range than regular BF amps, as it can actually cut treble. http://bmamps.com/Schematics/fender/...lux_manual.pdf
    If it's still too trebly, maybe there's something wrong with the amp, eg bad tube, bias too cold?
    Has it always been this way?
    If so, then yes, a different speaker type may significantly change the tone, but there's no need to go to the hassle of changing it from 2x10 to 1x15.
    Senior Member robrob's Avatar
    Aug 2015
    Tennessee USA
    135
    Is the speaker broken in? If not you may want to wait on mods until it is.
    First mod I would recommend is clipping the bright cap on the Bright channel volume circuit. This is a very common AB763 mod.
    *Deleted*
    Richard and mikepukmel like this.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,185
    What they said^^^^^^^^^^^^^^^
    But I guess I need to ask, what is too bright? If adjusting the treble control isn't sufficient then I need to ask why. That's not a cut, it's an inquiry. If, for example, you're clipping the amp then you need the treble up a little for good harmonic response and less farty bass. So in that case you can't just turn the treble down. So, is it harsh sounding when clipping? Is it just too bright clean? Does the amp lack bottom end? Do you want the treble, but it's to tippy and glassy sounding? There are a lot of versions of too bright.
    I can sure back what Rob said about breaking in the speaker. A lot of guys aren't crazy about the V30 speaker. I've always liked their upper mid character, but a little hashy on the top end. It took me a year to break one in for a 20W combo. Sounds great now. Best possible speaker for this amp. I hope I never need to break in another one But the point is just that it does make a big difference. Impatience ending in replacing your speaker can lead to a speaker that's too dark once it's broken in. That also happened to me.
    Richard likes this.
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
    Supporting Member
    Staffordshire UK
    3,321
    Quote Originally Posted by robrob View Post
    ...You can also clip the 10pF bright cap that's across the 3.3M reverb mix resistor...
    Rob, these amps have a rather different mixer circuit, and don't feature that nasty 10pF peaking cap (or anything similar).
    The normal channel is the exact same as the bright channel, except that it doesn't have the 47pF bright cap on its volume control.
    May 2007
    pacific north west
    13,185
    Ah, Right! They have it set up like the a vintage Vibroverb. I always wondered why Fender got away from that design, which was their first on board reverb and favored the 3.3M to 4.7M resistor with the 10pf cap instead.?.
  7. #7
    Chill-Ville, VA
    2,624
    Question:
    Is this the 90s Custom Vibrolux Reverb from the Pro Tube Series (Twin-Amp, Prosonic, etc.) or is it the newer "68 Custom Vibrilux Reverb" w. SF & drip edge? These are two quite different beasts, methinks... might make a difference which one we're looking at. I am thinking it's the 90s one with BF & white barrel knobs... but neither will be am AB763. Schematic?
    Justin
    pdf64, Chuck H and g1 like this.
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  8. #8
    Aug 2015
    Tennessee USA
    135
    I looked at the service manual you posted, there are lots of differences from the AB763. I edited my earlier post.
  9. #9
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,577
    What type of guitar/pickups are you using? If the amp is operating properly you might just want to invest in a stompbox eq? Or roll off your tone control? What genre are you playing? It's all very subjective. I prefer a slightly darker amp. I read the other day that Johnny Winter played a Firebird through a Twin with no Reverb on, the bass control on ZERO, and the channel, middle, treble and master all on 10! Would be an icepick to the head for me but sounded great for him!
  1. Replies: 23
    Last Post: 11-07-2017, 11:09 PM
  2. Vibrolux reverb custom issue
    By daz in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-15-2013, 02:48 PM
  3. Hissing Fender Custom Vibrolux Reverb - which mods really help ?
    By Iplayloud in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-10-2012, 02:12 AM
  4. Curing hiss: Fender Custom Vibrolux Reverb
    By Dave Curtis, dB AudioTech in forum Mods & Tweaks
    Last Post: 11-06-2011, 04:15 PM
  5. Replacement tubes for Custom Vibrolux Reverb
    By mottaz in forum Guitar Amps
    Last Post: 10-06-2008, 04:32 PM
