Results 1 to 5 of 5
Thread: 70's Ampeg Bass 410 combo
    Jun 2010
    180
    Ampeg combo has a couple bad filter caps. The old ones are huge.
    4800@60v
    I have 4700 @63 V snap in's which I assume should work fine. They are much smaller though.
    Any reason besides age why the oem caps are the size of 6l6's?
    Is there a different style cap I should use instead?
    Thx in adv
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,526
    Quote Originally Posted by guitardad View Post
    Any reason besides age why the oem caps are the size of 6l6's? Is there a different style cap I should use instead?
    Cap manufacturers constantly improving the product, now can put more energy storage into a smaller volume. No problem using the snap in ones you have, just adapt the mounting any way you can.
    Supporting Member loudthud's Avatar
    Near Dallas Texas
    3,321
    I sometimes use the 35mm diameter snap in caps because they fit the old 1-3/8 mounting clamps. 4700uF at 63V is only about 1-1/4 inch high so they look kinda funny.
    WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
    Jun 2010
    180
    Quote Originally Posted by loudthud View Post
    The ones I have do work, but they are rated at 1.7A ripple current, whereas other larger ones at Digikey are rated at 4.8A ripple current.
    Not usually a spec I concern myself with other than Voltage and Capacity. Does that spec matter much?
    This amp is high power with a 6A and 4A fuse in series. It eats a lot of electrons
    Near Dallas Texas
    3,321
    I would use the higher rated part. It probably costs more, but it will last much longer.
  1. Replies: 2
    Last Post: 06-22-2016, 02:40 AM
  2. Ampeg BA 210 combo bass amp help please
    By Big_Mike in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-09-2015, 03:09 PM
  3. Need Eden Nemesis RS-410 Combo Schematic
    By kilooonl in forum Schematic Requests
    Last Post: 02-11-2015, 05:54 AM
  4. 70's Ampeg V2: need some maintenance help
    By Jonny toetags in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-02-2013, 10:34 PM
  5. 70's Silverface Musicmaster Bass
    By bucky katt in forum Guitar Amps
    Last Post: 01-09-2011, 04:19 PM
