Results 1 to 7 of 7
Like Tree5Likes
  • 4 Post By Mick Bailey
  • 1 Post By Dave H
Thread: Scrapbox standalone low-voltage reverb
    Supporting Member
    Dec 2009
    UK
    2,969
    A couple of years ago I had an idea to build a tube reverb without the expense of special transformers. Here in England, tube (more correctly 'valve') transformers are pretty expensive and I wanted to see if something useful could be had from easily-available parts. Here's the schematic exactly as-built. It works very well, though I've yet to sort out switching the reverb on/off. I tried the usual method of grounding the input to the recovery tube, but this introduces too much noise.
    The transformer is a low-cost toroidal - just because that's what I had to hand.
    The TIP35C was used because it just happened to fit the spacing of my tagboard. Only the MOSFET needs heatsinking. The tray I used is from a mid-90's Marshall and I've tried a half dozen different other types and they all worked well. I'm not sure if the circuit will drive a Fender-type low-impedance tray, but the drive from the MOSFET is very strong.
    I know there are lots of design flaws, and room for improvement, but it works much better than you'd expect.
    Here's the final build, apart from finishing the case off;
    J M Fahey, g1, The Dude and 1 others like this.
    Cheshire, UK
    1,630
    At the bottom there's a diode shorting across the transformer. I think it should be connected to the other side (+ve) of the 4700u capacitor.
    J M Fahey likes this.
    Supporting Member
    Dec 2009
    UK
    2,969
    Well spotted - it's a half-wave voltage doubler.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,434
    COOL project, congratulations
    Jan 2014
    Chiraq
    727
    I like it too. Did you CNC your own faceplate??
    Supporting Member
    Dec 2009
    UK
    2,969
    No CNC - I have an old 60s 'Gravograph' pantograph engraver. I'm not too happy with the lettering - I had the depth of cut set too deep. The material is Traffolite - the original stuff that Hiwatt used.
  7. #7
    Supporting Member
    Dec 2009
    UK
    2,969
    Revised diagram with diode in correct position;
  1. Marshall standalone reverb unit
    By Mick Bailey in forum Music Electronics
    Last Post: 01-07-2016, 11:29 AM
  2. Replies: 20
    Last Post: 12-05-2014, 04:52 AM
  3. Organ Reverb to standalone Guitar 'verb
    By distorto in forum Conversion Projects
    Last Post: 08-23-2009, 06:17 PM
  4. Standalone Reverb Unit - Cabinet Dimensions?
    By thousandshirts in forum Cabinetry
    Last Post: 10-14-2008, 07:02 AM
  5. fender 6g15 standalone reverb distortion
    By joelw in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-25-2008, 10:48 PM
