Results 1 to 20 of 20
Like Tree8Likes
  • 1 Post By copperheadroads
  • 2 Post By big_teee
  • 1 Post By catalin gramada
  • 1 Post By rjb
  • 1 Post By nsubulysses
  • 1 Post By Raybob
  • 1 Post By Gingertube
Thread: 22 gauge tinned stranded 600v wire for heaters ?
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,053
    https://www.cedist.com/products/wire...g-50-foot-roll
    Would you recommend this product for heater wires as well as or generally area's in a 50 watt Marshall style build ?
    mikepukmel likes this.
    "UP here in the Canada we shoot things we don't understand"
    Mar 2008
    437
    The isolation is thick as hell. looks like a cable under norm of air and oil enviroment standard. It will be very hard to pose it discretly and aesthetic into electronic equipment. and functional as well
    Sep 2010
    Florida
    891
    I've used that wire before and its workability was good from what I remember. And I'm pretty sure it's fine for heaters. Never had someone call me about any problems... Here recently I did up my heater wire stock to 20awg but there wasn't any reason, just did.
    ~Semi-No0b Hobbyist~
    Jun 2009
    2,053
    If i was to build a marshall style amp & wanted to go with Red & Black heater wire like Marshall uses ,what would you recommend ?
    Mar 2008
    437
    Quote Originally Posted by copperheadroads View Post
    Noramco - Equipment, Hookup and Switchboard Cable Bare, Tinned, TEW, SIS, GTF, SR, Type B, TR64, GTO-15 Neon Sign Cable
    http://www.noramco.ca/pdf/ele01_07.pdf
    http://www.noramco.ca/pdf/ele01_05.pdf
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,568
    It may be overkill, but I don't go any smaller than 20awg for power tube heaters.
    Then 22 to preamp heaters.
    T
    copperheadroads and mozz like this.
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Terry
  7. #7
    Mar 2008
    437
    Quote Originally Posted by big_teee View Post
    T
    you're right. for preamps more than 22 will be difficult to hook into noval sockets. 18-20 to power tubes are welcome
  8. #8
    Jan 2014
    Chiraq
    845
    What about something like this? A thinner gauge but with ultra rugged insulation?
    https://tubedepot.com/products/18-ga...de-tefzel-wire
    This wire can be hard to work with but it's ultra strong and rigid, holds in place well, seems like it will last forever. I have used 20 and 18 guage of this type of wire in my builds without issue. for heater windings and everything else too.
  9. #9
    Jun 2010
    Mid-South USA
    10,568
    I've used some of this in different colors.
    They also stock the 600v wire.
    Hook Up Wire, 20 AWG, Solid, Red, 100 ft - Remington Industries
    This insulation doesn't melt too badly either.
    I bought a lot of pickup magnet winding wire from Remington, and they are a great company.
    T
    Keep Rockin! B_T
    Terry
  10. #10
    Jan 2014
    Chiraq
    845
    T
    This is a big point of contention for me for the wire posted in post #1. Actually I guess I just accepted it at first but then grew to hate it when i started using the Tefzel wire. I felt like I would never want to go back because you literally can't melt the tefzel insulation so it makes everything look cleaner.
  11. #11
    Mar 2008
    437
    In my oppinion solid wire rules. I used for everything and offer the advantage of physical stability. There is a litle bit confusion for me in American awg sistem cause the core diameters are not awg equivalent for solid and stranded. Talking about heaters I have some little tricks. I made myself the wires for heaters using double enamelled wire which I cover with thermocontractible tube, then I twist it. The ideea was to keep the wires as close as possible with very little isolation in between and with a very close pitch. That.s important to reject electromagnetic interference.
    In a past working with stranded I found PVC isolation as best.Why? because can be molded. Twist the wires into drill machine, keep it under tension when finish and heat it with a heat gun till start to soften. Keep it under tension till is cooling. You will get a rigid structure which retain the shape. you can untwist gently and still retain the twisted shape. Cut the twisted wire in pieces need it and just join the ends like shake the hands. It will looks like made from one piece and very rigid. Hope my english is understandable...
    Also want to add it is a good practice to pose the wires (specially the signal ones) "sticked" by chassis.That means it will beneffit by a "shielding effect". That.s easy to do with solid core
    eschertron likes this.
  12. #12
    rjb
    rjb is offline
    Feb 2010
    Just south of Bawlmer, Merlin
    2,493
    Quote Originally Posted by catalin gramada View Post
    You must have some pretty stiff guitar cables!
    The cross-sectional areas are the same; stranded wire has ~5% larger overall diameter because of geometry.
    https://en.wikipedia.org/wiki/Americ...wire_AWG_sizes
    The Dude likes this.
  13. #13
    Mar 2008
    437
    Quote Originally Posted by rjb View Post
    ...not quite. I don.t want to imagine what might happen if using a regular RG type CATV cable will sound beyond compare than most expensive cable I have...
  14. #14
    Jun 2009
    2,053
    T
    I said the same thing 20 gauge solid for heaters but finding the right wire from Ce distribution or Mojotone seems a little difficult . CE dist sells that cloth 20 gauge solid in green (fender style i guess) that is huge i have a spool of it & I didn't use it for heaters as it is too big & bulky
    I will be ordering some stuff from Remington so i will get it there. thanks to everyone but surely keep this thread going ...
  15. #15
    Sep 2009
    South Lake Taco, CA
    105
    Solid core 22 gage wire works fine for heaters/pilot light. Don't know if I'd try using stranded.
  16. #16
    Jan 2014
    Chiraq
    845
    I'm curious why people don't like stranded? Solid core is annoying to me because it breaks easily when bent. Maybe I've had too much bad experience with V4s
    g1 likes this.
  17. #17
    Sep 2009
    South Lake Taco, CA
    105
    Can't say I don't 'like' it, but same size wire solid core handles more current than stranded. 22 ga solid core works for heaters without getting hot. Can't say same thing about 22ga stranded, never having tried that.
    nsubulysses likes this.
  18. #18
    Mar 2008
    437
    It is a reason "hook up" wires are called for. You cannot make a hook with stranded one.
  19. #19
    Jul 2011
    Adelaide, South Oz
    679
    Wire has a continuous current rating in free air at a particular ambient temperature.
    The rating is based entirely upon the temperature rise in the wire + the ambient being below the temperature rating of the wire.
    That current rating gets reduced when wires are bundled together (as in 2 wires "bundled" for a heater wiring run) since there can be mutual heating from adjacent wires.
    That current get reduced again for higher ambient temperature (less temp rise in wire can be tolerated and still stay below max wire temp)
    Also gets reduced again for high altitude (e.g. use in aircraft) or if you live in Denver or some place high up. (Denver guys don't freak, the derating factor for you guys is like 0.95).
    Use this table
    Wire Gauges - Current Ratings
    Take the current values from the up to 3 cores (means 3 wires bundled) column.
    It gives you conservative and therefore safe values (typical values of all those de-ratings mentioned have already been applied).
    Note that it tells you 3 Amps max. for 22 AWG heater run.
    I typically run 16 AWG to power tubes and 20 or 22 AWG to preamp tubes.
    I also do aircraft equipment design where we have to do all those calcs. for each wire and prove that there is a fuse or circuit breaker of lower than the wire current rating in the feed to that circuit - to get CASA (Aussie version of FAA) design approval.
    Cheers,
    Ian
  20. #20
    Sep 2014
    Richmond Va
    18
    This 22awg Topcoat wire is my favorite in my Marshall style builds. It is pretinned for easy soldering, holds it shape great and the insulation holds up great to soldering heat...http://valvestorm.com/Products/Wire
  1. 22 gauge in heater wiring..?
    By überfuzz in forum Guitar Amps
    Last Post: 08-18-2010, 06:23 AM
  2. Stranded copper wire for filaments?
    By pizzyflavin in forum Tweed Builders
    Last Post: 05-21-2010, 05:28 PM
  3. wire: stranded vs. solid core
    By mook in forum Theory & Design
    Last Post: 05-20-2010, 08:12 AM
  4. Source for 600v solid core hook-up wire ?
    By Paul P in forum Build Your Amp
    Last Post: 08-05-2007, 02:11 AM
  5. 20 Ga 600V 105C PVC Solid Hookup Wire?
    By Smitty in forum Guitar Amps
    Last Post: 10-17-2006, 05:07 AM
