| | #1 |
| Supporting Member Join Date: Mar 2007 Location: UK
| Fisher X-100 info/experience/opinions?
In the right forum this time: I realise this is not a schematic exchange, but if anyone has circuit info on the 1970s Fisher X-100 tube hi-fi amp, or anything else of interest to say, I would be most grateful, not to say reciprocal. Specially the power supply - this one has been converted to SS diodes with a big resistor across them to cut voltage (presumably) - not surprisingly perhaps, given the resistor, the power txr is shorted, and I will be converting it back to a GZ34 when I fit the new txr. I can work out some good values etc but it would be nice to have total 'originality'. 4 x EL84, 6 x preamp valves, ECC83 and ECC832. 275-0-275 into the GZ34 for 350ish volts B+, I'm assuming... |
| | #2 |
Did you google "Fisher X-100 schematic"?
| | #3 |
Well I thought I did but something in your tone makes me want to go and do it again...
| | #4 |
Mm... didn't look quite hard enough did I?
| | #5 |
Actually it was just a suggestion, I had not done so myself.
| | #6 |
- good suggestion because I found a source. Thanks.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Opinions on cap values | madialex | Pickup Makers | 17 | 03-02-2008 12:37 AM |
| Anyone have experience with the Ceria Tone DC30 board or build? | Thorny | Kit Amps | 21 | 03-31-2007 10:51 PM |
| Fisher SA-300 Schematics | Amp Kat | Vintage Amps | 2 | 02-08-2007 12:13 AM |
| Torres Engineering "Tone Frenzy" - Experience? | ian2113 | Build Your Amp | 4 | 11-26-2006 05:50 PM |
