Results 1 to 13 of 13
Like Tree7Likes
  • 3 Post By Tom Phillips
  • 1 Post By mozz
  • 2 Post By pdf64
  • 1 Post By Gingertube
Thread: Lower Heater Voltage With Lower Center Tap Resistors?
    Senior Member robrob's Avatar
    Aug 2015
    Tennessee USA
    135
    I haven't tried this yet but was wondering if anyone has. Many amps run high heater voltage due to higher wall voltage or possibly due to over rated power transformers so I'm thinking about using lower resistance value center tap resistors to sink some extra current to ground.
    I have always used two .1 ohm 2 watt resistors on a little perf board to lower heater voltage. I run each heater line through one of the resistors to keep the voltage balanced but I'm curious if anyone has tried lowering the center tap resistance. I realize this will push the power transformer harder.
    Here's the math:
    With 6.9v wire-to-wire each center tap resistor sees approximately 3.45v
    220 ohm resistors sink 15.6ma at .05 watts
    100 = 34.5ma .12 watts
    47 = 73ma .25 watts
    10 = 345ma 1.2w
    Jun 2006
    California, USA
    3,446
    Your traditional method of putting each heater line through one resistor to drop excess voltage is the best way to go. That method actually reduces the current load on the transformer while it reduces the voltage reaching the tube heaters.
    The other proposed method of reducing the virtual center tap resistance to load the transformer winding and thus reduce voltage is very bad practice for several reasons.
    1) Increases stress on the transformer
    2) Increases heat dissipated inside the chassis
    3) Requires higher wattage / more expensive resistors
    4) Just plain inefficient. It is analogous to reducing the speed of your car by riding the brake rather than letting up on the accelerator.
    Dave H, pdf64 and J M Fahey like this.
    Supporting Member
    Staffordshire UK
    3,278
    Back to back diodes as a series dropper are an alternative to a resistor. Given the high current nature of the circuit, it may not reduce heat much though.
    Aug 2015
    Tennessee USA
    135
    Quote Originally Posted by Tom Phillips View Post
    #1 I agree and this is my primary concern.
    #2 The extra .1 ohm voltage dropping resistors generate heat inside the chassis.
    #3 The extra .1 ohm 2 watt resistors cost pretty much the same as higher watt center taps.
    #4 The extra .1 ohm resistors are inefficient too, they are also turning electric power into heat.
    The pro is the amp looks cleaner without having the voltage dropping perf board inside the chassis. This is why I'm investigating this mod.
    May 2015
    Fayetteville, AR USA
    298
    I used to have a separate transformer on my breadboard devoted to heaters (so that heaters could run at full voltage when I ran the transformer supplying the HV at lower voltages via the variac). It was an old Thordarson and its heater voltage was too high (either because line voltage differences or because the HV was unloaed, or both) and I used the same technique. Resistors on both sides. Never had an issue with it.
    Aug 2015
    Tennessee USA
    135
    pdf64, what diode circuit would you use to drop .5v from each heater line?
  7. #7
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,051
    But the wasted power is way higher, and to boot *inside* the transformer, because you are using the wire own internal resistance to do so.
    A horrible "solution".
  8. #8
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,689
    Quote Originally Posted by pdf64 View Post
    To drop as little a 0.5V is a tough call. You'll need to use a beefy low voltage Schottky rectifier to get close. For example the SR520/30/40 in the attached datasheet will drop 550mV at 5A:
    SR520.pdf
  9. #9
    Aug 2015
    Tennessee USA
    135
    Thanks Juan, I'll scrub the idea.
  10. #10
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    480
    If you use .1 or .22 ohms on each leg to drop the filament voltage, you are not putting that much heat under the chassis. I take out the #47 bulb and put a led bulb in there saving 150ma.
    Nice dropping calculator here. http://www.mh-audio.nl/DroppingResistor.asp
    Chuck H likes this.
  11. #11
    Aug 2015
    Tennessee USA
    135
    After the feedback in this thread I have decided to scrap the idea. Thanks everyone for the help.
  12. #12
    Supporting Member
    Staffordshire UK
    3,278
    Excessive heater voltage may be a good indication that the PT is being fed a higher primary voltage than it was intended for; hence a mains bucker before the primary may be the best (and lowest loss) option.
  13. #13
    Jul 2011
    Adelaide, South Oz
    676
    We talked about heater voltage on this thread - some reliable technical info:
    Effects of too much heater voltage?
    Cheers,
    Ian
    Chuck H likes this.
  1. voltage dividers vs. lower value pots?
    By EFK in forum Theory & Design
    Last Post: 01-07-2011, 01:35 AM
  2. Heater center tap
    By lowell in forum Theory & Design
    Last Post: 01-15-2010, 10:41 PM
  3. Heater center tap
    By Rocketrob in forum Theory & Design
    Last Post: 03-16-2009, 08:44 PM
  4. Using a pot instead of 2 resistors for a heater center tap
    By CitizenCain in forum Theory & Design
    Last Post: 05-27-2008, 03:59 PM
  5. How To Lower Ac Filament Voltage?
    By RANDY in forum Theory & Design
    Last Post: 10-10-2006, 07:09 PM
